grusks2
| posted on 31/10/08 at 09:05 PM |
Reverse Gear / Bike Engine
As the new Sva test is on the way in april ( im hoping to be finished before then as long as work picks up) what on offer in the way of reverse gears
for the Worx's.
[Edited on 31/10/08 by grusks2]
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
| posted on 31/10/08 at 09:20 PM |
1) Mechanical inline reverse box
2) Electric reverse "home-brew"
I'm not aware of any off-the-shelf electric reverse mechs. I think STM sold one but it was fairly home-brew IIRC... (ie in constant
development)....
| posted on 31/10/08 at 09:39 PM |
Hmm, my gearbox came with reverse. A Ford type 9, and the Toyota W58 going in has reverse as well.
Why not use a box that has reverse??
stuart_g
| posted on 31/10/08 at 10:21 PM |
How boring are these constant remarks, yawn, yawn.
If you have nothing constructive to offer in a post regarding BEC's why bother posting. Your constant anti BEC is getting very boring. You
don't see BEC owners heckling every post you put up so why do it to posts put up by BEC owners?
AB Performance does a mechanical one supposed to be good quality or there is this one
[Edited on 31/10/08 by stuart_g]
| posted on 31/10/08 at 10:31 PM |
Because then I'd always be jealous of those with a BEC and would find it necessary to mercilously mock them
grusks2
| posted on 31/10/08 at 10:47 PM |
[quote
Thats better a proper answer , Have you a web site for AB performance.
I fancy the electric route to be honest, all ready got my propshaft, so dont really want another 2 made up for the reverse box route.
This post was meant for the owners of mac#1 and what have they done or going to do reverse gear wise.
tomgregory2000
| posted on 31/10/08 at 10:56 PM |
cut 2 holes in the floor and tell them that u want to do it flinstone style and use your feet, they cant argue with that
YQUSTA
| posted on 31/10/08 at 10:59 PM |
http://www.abperformance.co.uk/default.htm
Also these guys
http://www.lynxae.co.uk/Products-Bikesports.htm
spoke to them a while back very helpfull guys
YQUSTA
[Edited on 31/10/08 by YQUSTA]
Triton
| posted on 31/10/08 at 11:16 PM |
Take one bike starter motor and have gear cut in some kind of plastic to match the pitch on starter...mount gear on diff like a space then rig up
starter to either slide into place or have it lowering...
plastic gear will shear teeth if something goes pear shaped and accidently chunks into reverse. go as big as you can in the given space for the gear
and will throw you backwards quicker than you imagined a wee bike starter should!
those reverse box things are heavy and if memory serves me right turn into "oil pumps" and chuck oil everywhere
www.tritonraceseats.com
www.hairyhedgehog.com
Bigheppy
| posted on 31/10/08 at 11:41 PM |
This is a valid comment, has anyone investigated using a car gearbox on a bike engine. I know many will comment on the weight and complexity of a car
gearbox but it could be an answer to many peoples prayers.
AdrianH
| posted on 1/11/08 at 12:00 AM |
But generally the bike engine has the gearbox built in.
That helps with the power to weight ratio.
To take a drive without the gearbox would mean a lot of mods to crankcase etc.
The last time I saw one without, was on a Triumph pre-unit twin, then there is the American series of twin cylinder lumps as used on American
Chopper.
On Saying all that what does a VW air cooled engine use, that has a separate box
Adrian
[Edited on 1-11-08 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
trialsman
| posted on 1/11/08 at 01:43 AM |
I think he means using a car gear box in ADDITION to the bike gear box. It would be in line with the prop shaft. Take a gear small box (like a Suzuki
Samurai) cut the bell housing off. Attach the bike output to the gear box input. Gut the gears out of it leaving only the 1:1 ratio forward gear and
the reverse gear. I don't know if it is possible or not. Seems feasible. Russ
[Edited on 1/11/08 by trialsman]
zilspeed
| posted on 1/11/08 at 09:10 AM |
Me - I have considered it.
I think with the right box it's very much the locost way. Light gearbox is the answer.
More updates very soon.
irvined
| posted on 1/11/08 at 12:33 PM |
There was a guy a while ago with a green busa powered seven and a car gearbox. I can't remember the configuration, but there were some videos
posted.
http://irvined.blogspot.com
| posted on 1/11/08 at 06:35 PM |
Well, I get constantly bombarded with comments like 'should have put a bike engine in it' but that wasn't the point of my post. It
was abit tongue in cheek I admit.
Reverse boxes for bike engines are ridiculously expensive but car gearboxes have a reverse gear and shift. Isn't about time some one found a way
of using a car gearbox as a secondary gear up or down device with reverse?
This is a forum, and forums are about discussion.
TPG
| posted on 1/11/08 at 06:36 PM |
A good point, A friend of mine built a JZR a quite few years ago with a Hardly Dangerous engine in it. He mated that upto a Ford gearbox. Now what
bike engine is North-South I don't know.The V-twin looked bang on in a very early Morgan replica.How you go on for a locost style.....
..Which was nice..
zilspeed
| posted on 2/11/08 at 04:02 PM |
I have done just that.
Yesterday I pciked up an adapter from a member of this forum who has a waterjet machine.
Centre spline are the same as a ford small clutch, four bolt holes are the same as Ford propshaft PCD.
Can you see where this is going ?
Pics when I find my pheqin' camera.
