Author: Subject: Sealing / Securing cv boots.
Flamez
posted on 2/7/09 at 07:45 PM Reply With Quote
As per the title really,
I have a Freelander diff and I have purchased new boots from Landrover that are shaped specifically for the diff. I have tried to secure the boots twice by using tie wraps.
However on inspection there is a line of grease around the boot area where the boot has obviously leaked and been thrown out.
Is it a simple matter of trying to get the plastic ties tighter?
Could there be too much grease in the boot?
Should I try and seal using a gasket sealer?
Should I use a large jubilee clip?
Any suggestions.
my build mac1motorsports
adithorp
posted on 2/7/09 at 08:05 PM Reply With Quote
I secure them with stainless ties but you need the tool for them ideally. Nylon ties aren't ideal as they stretch a bit although you'll see lots done with them. I wouldn't recommend sealant. It'll be very hard not to contaminate it with grease and can also act as lubricant to let the boot squeeze off the joint. Jubilees do work as long as there's room for the screw but are often a bit wide sometimes. I often use them where a car has plastic boots (Renault, GM, etc) with broken straps and standard ones won't tighten enough.
adrian
[Edited on 2/7/09 by adithorp]
http://jpsc.org.uk/forum/
posted on 2/7/09 at 10:03 PM Reply With Quote
I've never got the stainless strips to work... For me it's uber-tight tie-wraps every time....
loggyboy
posted on 2/7/09 at 11:55 PM Reply With Quote
I used a large jubillee clip
adithorp
posted on 3/7/09 at 12:26 PM Reply With Quote
This sort? Have you got the fitting tool?
grusks2
posted on 3/7/09 at 05:57 PM Reply With Quote
Mine had the same line of greese by the diff underneath, i cleaned it off after 100 miles etc and its stayed clean, ive used cable ties, if it starts to leak again jubilee clips
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
Flamez
posted on 3/7/09 at 06:51 PM Reply With Quote
Thanks spence, thats exactly what I am planning. Off to anglesey on 19th July I'll let you know how I get on.
