<<  1    2    3    4  >>
Author: Subject: Mac Worx RR build thread
kimbo1982
posted on 30/9/11 at 10:47 AM Reply With Quote
That is a stunning build, just spent half hour reading your thread on pistonheads!
SausageArm
posted on 22/1/12 at 08:28 PM Reply With Quote
Thanks very much, glad you enjoyed reading it
SausageArm
posted on 22/1/12 at 08:41 PM Reply With Quote
To further improve the cooling I decided to fit a second radiator in the boot area, I need a new header tank, with larger volume and more inlet/outplet ports, so some aluminium sheet was bought and cut to size
then the TIG set was fired up and i set about joining the bits together, my aluminium welding is far from perfect but it's improving
The header tank is progressing, still a long way to go but it's taking shape nicely
One radiator, Davies Craig water pump, hose elbows and hose adaptors/joiners.
The radiator fans trial fitted them to the radiator, to double check they would actually fit as planned.
With the roll bar removed, it made access for fitting the radiator much better, some aluminium brackets were cut and welded to the radiator, rivnuts fitted into the chassis, and the radiator mounted.
The radiator fits in the space rather nicely, happy days
Next up, the fans were trial mounted again, so the top panel could be fitted and see how much it needed to be cut to clear the three fans.
The angle grinder was fired up and a small amount was cut from the bottom area of the top panel, rested in position, clearance looks great.
As I tidied the tools away for the night, I took the opportunity to rest the roll bar back in place, this is how it looks.
With the cover on the boot area of the car, this is all you can see of the radiator/fans inside. I'm planning on joining up the large and small holes to make teardrop shaped vents, then meshing the holes from the underside, this will be done at the same time as the vents on the bonnet are meshed up.
My DIY header tank has been pressure tested, found to be leak free and then installed
The cooling issues are now resolved , the new radiator in the boot has done the trick, on the move temps dont go above 90 deg C, through traffic temp peaks at 95 deg C.
SausageArm
posted on 22/1/12 at 08:43 PM Reply With Quote
Racetech mirrors have now been fitted
SausageArm
posted on 22/1/12 at 08:46 PM Reply With Quote
To overcome the issue of not being able to press the clutch in with the lockup clutch while the engine is doing high rpm's, I have invested in one of these
http://www.flatshifter.com/flat-shifter-expert/
The Flatshifter Expert quickshifter provides effortless full or part throttle clutchless upshifts and auto throttle blipped downshifts without using the clutch, so the car should be a real pleasure to drive once I get this kit strapped on, it should make it a tad quicker on track too according to Flatshifters claims.
The Flatshifter Expert kit is now fitted, tested it in the garage and the blipper worked a treat, with the engine at idle changing up and down the gears without the clutch was easy, if a little jerky, but the fitting instructions did mention this.
I've been out in the car today, first drive with the Flatshifter on the car, going up through the gears is so quick it's fantastic! Changing down the gears while carrying reasonable speed is silky smooth, at lower speeds it's not quite perfect but this can be fine tuned to your personal preference.
All in all i'm a happy man
SausageArm
posted on 22/1/12 at 08:48 PM Reply With Quote
It was high time the horrid ratchet strap over the inlet manifold was removed, so without further ado it was taken off.
The motor/position sensor was also removed from the throttle bodies secondary butterflies, this made a nice space to allow some straps to be fitted to secure the inlet manifold down.
Some aluminium strips were cut, bent and drilled, once fitted to the engine they look like this
Looking at those last two photos, the wiring and vacuum hoses need some tidying because they look a right mess.
As agreed with Damien at Daytuner, the Power Commander has been fitted to the car but not connected up, that will be carried out when I get there.
Oil and water levels checked, tank filled up with V-Power, a set of NGK Laser Iridium spark plugs packed to be fitted prior to mapping, crash helmet and warm clothing sorted, that's me set for the trip out to Daytuner in Harrogate tomorrow... fingers crossed the weathers good and the results are even better!
SausageArm
posted on 31/1/12 at 09:58 PM Reply With Quote
A couple of videos from the mapping session, running 8psi (low boost)
Video 1 with a flame
Video 2 with more flames
<<  1    2    3    4  >>
