Author: Subject: recommendations for noise reduction
davida
posted on 8/1/09 at 10:52 PM Reply With Quote
Evening all.
I'm looking ahead to some track days this year but am a little concerned about the noise limits.
After fitting a custom airbox the noise has reduced quite a lot from the CBR1000RR engine in my Mac#1 but I suspect I'm still pretty loud - I cetainly rattle my neighbours windows and I'd hate to turn up to a track and get red carded staight away.
I'd welcome any recommendations for quieter exhausts
Dave
Dangle_kt
posted on 8/1/09 at 11:15 PM Reply With Quote
There is a button on the dash that if you don;t press it your car remains SILENT!
Your lap times will suffer though...
Have you repacked exhaust? Is exhaust system standard? shortie can, straight through can?
If you are sure the induction roar is the problem
Is it a standard airbox/ These are designed to reduce noise, whereas ones that fit easy on a 7 tend to focus more on performance ...which as you seem to understand, is kind of pointless if you can't get onto the track!
mark chandler
posted on 9/1/09 at 12:11 AM Reply With Quote
Standard bike can and airbox, if the exhaust points out try directing under the car, if you already have a standard air box try adding some convoluted tubing from the horns and lose them within the nosecone.
Noise gets quietened with bends, unfortunately it does cost power.
Where are you, find a noise friendly track like Lydden if down south, avoid somewhere like Bedford Aerodrome where you do not get second chances.
Regards Mark
A1
posted on 9/1/09 at 12:46 AM Reply With Quote
where are the noise friendly tracks? preferably up northish? is there anywhere they just dont bother about it??
bob tatt
posted on 9/1/09 at 06:40 AM Reply With Quote
both cadwell and oulton have 103 limits static and rockingham is 105 i know this is a fair way from you go on to the trackday wabsites it tells you on there what the noise limit is on a given day. try to borrow a sound meter off someone i know book a track will lend you one for a small fee
Mr Whippy
posted on 9/1/09 at 08:49 AM Reply With Quote
Can’t you just stick on a baffled car silencer. For all the power loss at least it gets you on the track.
bimbleuk
posted on 9/1/09 at 10:09 AM Reply With Quote
You could also shield the primaries as they come out of the head. Maybe wrap them or insulate the hood/side panels.
Mr Whippy
posted on 9/1/09 at 10:21 AM Reply With Quote
yip cos they make a right racket with all that valve clatter
iank
posted on 9/1/09 at 10:28 AM Reply With Quote
What about a rotary silencer aka a turbo?
Anonymous
dean100yz
posted on 9/1/09 at 02:07 PM Reply With Quote
If you like the current exhaust setup you can fit a db dawg or similar (there's a few different makes out there). It fits into the end cap and drops the db a few point. Not much but it can be enough to make the difference between doin a trackday and not. I've used them in the past for both road and moto x bikes when racin acu
