Slater
| posted on 9/1/09 at 01:56 PM |
Rear Arch Protector Dims
Hello, I am currently offshore Nigeria on board the Scarabeo-3, a semi-sub drilling rig.
I have spotted a nice bit of stainless sheet on the rig. I'd like to cut out and make some rear arch protectors, but I don't have any
dimensions with me.
Can anyone help me out and let me know what the protector dimensions are to suit the MAC#1 rear arches please, or even draw a template and scan in so
I can print off on an A4 sheet/template.
Since arriving I have allready made/stamped a chassis plate,also "obtained" some ali section for a bonnet vent idea.
Keith
Right, that's me off the get my daily excercise- 45 min walking in big circles round the helideck with my ipod.
DarrenW
| posted on 9/1/09 at 03:44 PM |
Hope you are catching some sun while doing your exercise.
Cant remember the size, however do recommend making them as big as you can. Full width, starting right at the bottom and going quite high. I fitted a
std set of abs plastic ones and the arches got peppered right around them. Some front mud flaps are a good idea. Stop a lot of the stones etc and when
raining hard cut down the water hitting your elbow which eventually collects in seat base (after taking a trip around your crotch area) and making
your derrier damp.
Slater
| posted on 10/1/09 at 12:42 PM |
[Edited on 10/1/09 by Slater]
Slater
Yes it's sunny and warm (30-35 C) here.
Can someone please measure the width/height of the front of the rear arch so I can chop up this bit of stainless to the right size and smuggle it back
to the UK. I can trim it to the right shape once I get back home.
My other alternative is to ask the wife to go into the garage with a tape measure, but you will know how enthusiastic she is about kit cars from her
commentary in my first drive video clips!
Keith.
neilj37
| posted on 10/1/09 at 02:32 PM |
I could measure the ones fitted to my MNR which may be close if that helps ?
Slater
| posted on 10/1/09 at 04:36 PM |
Yes please Neil, I think I will make the protectors as big as possible, following advice from Darren above. So can you measure the flat width of your
arch at the front and then the height from bottom to where the protector might end. I will cut them on the big side anyway and trim them at home.
Keith.
neilj37
| posted on 11/1/09 at 08:25 AM |
My protectors would approx 240mm x 450mm flat at their widest dimesions.
[Edited on 11/1/09 by neilj37]
bigrich
| posted on 11/1/09 at 01:08 PM |
mine a diamond shaped as opposed to flat topped
[Edited on 11/1/09 by bigrich]
Slater
| posted on 13/1/09 at 10:31 AM |
Thanks Neil for the dimensions and advice from BigRich and Darren. I got the rig welder to cut them out for me. I think it was the door for an
industrial washing machine. I gave him 2 mars bars and he was delighted.
The rig have also just skipped a 15ft long galley worktop and cupboards. All made from shiney stainless. Enough to panel an entire car!
Oh well, I will bring home my 2 sheets in my case.
[img][/img]
