daz9
| posted on 23/5/09 at 02:20 PM |
throttle return spring
can any-one help me with fitting a throttle return spring to the carb end on my r1 powered mac 1, it has been fitted with a return spring on the
accelerator pedal which i'm sure is not right as the resistance is too strong?
blakep82
| posted on 23/5/09 at 02:25 PM |
sometimes you find the spring on the carbs, while ok for the bikes twist grip, sometimes isn't strong enough for a pedal. this is why
you've got the spring on there.
now you ask for help, but what help do you need?
________________________
a4gom
| posted on 23/5/09 at 02:30 PM |
which R1, I asked about this recently and someone sent me a picture of a good idea for the 5VY using the place the original throttle closing cable was
fixed.
Perfect planning prevents pi$$ poor performance!
daz9
| posted on 23/5/09 at 02:40 PM |
im not sure where i can mount the spring on the carb end of the cable, i do not know which r1 engine i have fitted only that it is a carb model, is
there somewhere on the carbs that i can fit a spring for the best reliability as the pedal one has snapped twice!!
daz9
| posted on 23/5/09 at 02:52 PM |
fixed.
could you forward me the picture if poss as this may help me out, thanks
daz9
| posted on 23/5/09 at 02:53 PM |
i am not sure how or where to mount a return spring the carb end so i can eliminate the need for one on the pedal.
Slater
| posted on 23/5/09 at 03:11 PM |
This is how I fitted a throttle return spring to my ZZR carbs. There is a special hole to accept the nipple and the cable was cut approx 6" from
the nipple with the arrangement below fitted to the other end, it works a treat.
I have a selection box of various springs left over if you want me to send you some.
[img][/img]
daz9
| posted on 23/5/09 at 03:20 PM |
i will strip mine down tomorow and see if i can see if its similar , i was hoping to fit a hook type spring to pull it back but i will see if i can
adopt your great idea, thanks
[img][/img]
DarrenW
| posted on 26/5/09 at 10:58 AM |
I had to fit an extra return spring to my ZZR1100 carbs fitted to pinto on Mac#1 ZR. With a lighter spring the throttle wasnt shutting off fast enough
and revs were too high when changing gear. Extra spring cured it but does result in higher throttle resistance. Either get used to the throttle the
way it is or try a slightly lighter spring. I bought a boxed set of assorted springs for about a tenner - worth having in stock.
