daz9
posted on 24/5/09 at 08:29 PM |
mac 1 steering specs
can any one give me the correct tracking or steering geometry for a mac 1 type 9 r , thanks
Flamez
posted on 25/5/09 at 03:04 PM |
mark at the factory told me to leave everything neutral at 0 degrees, It was then set up at the factory.
my build mac1motorsports
DarrenW
posted on 26/5/09 at 11:02 AM |
Are you after IVA settings or road settings? They are subtly different to allow correct amount of self centering at the test. For the road im running
between -0.5 and -1deg camber and slight toe in, i do get some self centering too with correct road settings but not as much as when set up for the
test. For SVA i ran high tyre pressures (between 35 and 40 psi), neutral camber and quite a bit of toe out (iirc).
[Edited on 26/5/09 by DarrenW]
