stupott901
posted on 10/8/09 at 07:10 PM |
blade starting prob
hi there
i have been having problems starting my blade engine
it seems to be the plugs as if i put new ones in or clean them it starts ok
when i take them out they black ,wet and smell heavily of fuel
what could be causing this
cheers stu
Steve Hignett
posted on 10/8/09 at 07:19 PM |
One (or maybe more) of your float bowls is flooding/overflowing.
Try tapping it (gently!) with a ring spanner to hopefully dislodge whatever dirt or grime that may be causing the float-bowl needle to not sit flush
and therefore overflow...
mad-butcher
posted on 10/8/09 at 07:55 PM |
Std airbox or other type, have you changed anything lately. has it been run lately. tend to agree with above
tony
stupott901
posted on 10/8/09 at 08:02 PM |
its a foam sausage filter not changed anything else
it was running yesterday after cleaning plugs an ran for 3-4 miles
cheers stu
Dangle_kt
posted on 10/8/09 at 08:27 PM |
have you messed with the fueling recently? dynojet gone wrong?
Gav
posted on 10/8/09 at 08:28 PM |
How old is the fuel? i know mine started to gunk up the carbs but m fuel was 2 years old
stupott901
posted on 10/8/09 at 08:32 PM |
nope not messed about with fueling only changed fuel pipes
and its fresh fuel
posted on 10/8/09 at 09:08 PM |
carb flooding ---- ie fuel pressure
stupott901
posted on 12/8/09 at 08:44 AM |
it should not be fuel pressure as i i got an facet low pressure pump 1.5 psi
the fuel is quite new bought on monday
gixermark
posted on 12/8/09 at 09:02 AM |
do you still have the choke connected ?
mad-butcher
posted on 12/8/09 at 01:57 PM |
Are facets interuptor pumps ie shut down when it meets resistance (float needle closing)
or are they designed to have a return.
tony
