Author: Subject: Balancing R1 carbs
james h
posted on 15/8/09 at 05:24 PM Reply With Quote
Balancing R1 carbs
Drove my car to get emissions tested today. It was the first time I have driven it - yay! But my gearshift sort of broke so I had to drive home in 1st in the rain Still fun though
So my question is, having leaned out the mixture, i.e. screwed the idle mixture screws in more, how can I now balance the carbs? Is there a DIY version? I seem to remember somebody saying that the vacuum takeoff or something isn't on the carbs...
James
omega0684
posted on 15/8/09 at 05:49 PM Reply With Quote
for r1 carbs you need to get a carb balancer that you place over the end of the trumpet, which the sebsequently measures vacuum or air flow etc?
they are available on ebay cheaply enough
Dingz
posted on 16/8/09 at 12:11 AM Reply With Quote
This may help as a starting point.
Assuming the timing is already correctly set start off by setting the idle screws all the same 2 ½ -3 turns out, then balance the carbs when it is running either with a flow meter or listening to the sound of the suck with a bit of rubber hose. One of the carbs is the master, probably the one with the cable connected so get the next carb in the line sucking the same amount by adjusting the throttle linkage screws, then the next and so on. You will have to adjust the idle speed as you do this as the revs will be going up and down. This will give you a good starting point, if there is a lot of spitting back through the carbs at idle and slight throttle opening or overrun then the idle mixture needs richening. If the exhaust is sooty after normal driving then perhaps the needles could be lowered to lean the mixture if it is sooty after a real thrashing then the mains are probably too big. Conversely if the exhaust is very pale and it struggles under load then the needles need raising and possibly bigger mains, but without a rolling road session it will be just trial and error, do runs then check plug colours to get an idea of what is going on.
Coose
posted on 18/8/09 at 11:13 AM Reply With Quote
Click me!
I've posted the cheapest way to do it a zillion times......
Spin 'er off Well...
james h
posted on 18/8/09 at 11:16 AM Reply With Quote
Originally posted by Coose
Click me!
Yeah sorry about that, I only saw your posts after I made mine I probably spelt something wrong when using the search...
