MakeEverything
posted on 21/9/09 at 03:03 PM |
Which Lambda?
So which O2 sensor is best for a 1.8 Zetec on MS2.2? Narrow or Wide Band?
I want to leave it connected if poss, so the cheaper the better.
Kindest Regards,
Richard.
omega0684
posted on 21/9/09 at 03:05 PM |
wideband are the best for tuning have a look at the innovate lc-1 kit
cd.thomson
posted on 21/9/09 at 03:07 PM |
on the assumption cheaper = better. Off the mark narrowband is the leader, but when you consider its only going to be drivable after its been tuned by
somebody with a wideband sensor anyway then WB comes out on top.
Craig
flak monkey
posted on 21/9/09 at 03:11 PM |
Wideband all the way
Import an LC1 from the states, works out about half the price of over here even if you get stung on import duty (which is only about 3% anyway)
Sera
http://www.motosera.com
posted on 21/9/09 at 03:20 PM |
If you go wideband you'll need to leave it connected to the juice whever the car is running. By all accounts if you don't the end gets all
crudded up and it breaks the sensor.
MakeEverything
posted on 21/9/09 at 03:23 PM |
Cool, Thanks Guys.
Will narrow band work at all?
Kindest Regards,
Richard.
posted on 21/9/09 at 03:50 PM |
quote: Originally posted by MakeEverything
Cool, Thanks Guys.
Narrow band is fine for keeping an already mapped system on target as components wear etc. but it's not really possible to accurately map and
engine with it.
GrumpyOne
posted on 21/9/09 at 04:02 PM |
Would you need two wideband sensors for a V6?
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
nitram38
posted on 21/9/09 at 04:04 PM |
I have the LC-1 and XD-16 gauge on the MotaLeira. About £180 delivered from Ebay USA.
posted on 21/9/09 at 04:49 PM |
No. It's not like you're tuning individual cylinders after all.... If you have twin pipes (like me) you just use the lambda results from
one side to control both sides.
MakeEverything
posted on 21/9/09 at 05:13 PM |
The ford cologne v6 had two in the headers, one for each side.
Kindest Regards,
Richard.
posted on 21/9/09 at 06:39 PM |
Cool, Thanks Guys.
engine with it.
Not exactly true! I managed to get my engine very close using a narrow band sensor with an Emerald ECU , so close in fact that Dave Walker
complimented me on getting it so close . Not saying that it was easy or that you won't benefit from a good rolling road session. It is in fact
possible to use a multimeter and narrow band sensor to map an engine but it's not something I would recommend
sebastiaan
posted on 21/9/09 at 07:10 PM |
Cool, Thanks Guys.
engine with it.
Indeed. If you're tuning an atmo engine then it can be done with relative ease if you know what you're doing. A turbocharged engine is a
bit more difficult but also not impossible. I did my pinto with a narrowband and it's more then fine.
A wideband's just easier and a bit more flash.
posted on 21/9/09 at 07:53 PM |
The trouble is you can get the engine to run somewhere around stoich, which is fine for most conditions, but richening it up at WOT or leaning it out
under cruise is very hit or miss, you know the engine ir running lean or rich, but not really by how much.
sebastiaan
posted on 22/9/09 at 06:12 AM |
If you know where stoich is, you can calculate how much you need to add/subtract to get to your preferred AFR. Not that difficult, really....
