Author: Subject: All bar one
rickys2000
posted on 24/11/09 at 06:28 PM Reply With Quote
All bar one
As it says IVA retest today and a disappointing failure.
This time noise levels hit 96 decibels, self centering was perfect and indicators e-marked. However still failed on one item - the park brake got 16% efficiency versus 18% pass mark.
Bottom line is that the Wilwood Powerlight handbrake caliper is just not getting enough mechanical leverage to secure the pad against the disc, no matter how hard you pull the h/brake up. Have spoken to Rally Designs Andy and he is going to try and design a revised mechanism that puts extra leverage directly on to the caliper. Once done hopefully will be good enough.
Anyone else had this problem?
Ricky
mads
posted on 24/11/09 at 06:29 PM Reply With Quote
sorry to hear about your IVA fail.
Keep us posted as i have some of these calipers and am now concerned....
[Edited on 24/11/09 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Flamez
posted on 24/11/09 at 06:33 PM Reply With Quote
Mine were similar, i wonder if the examiner pressed the brake pedal for me, such a nice guy
my build mac1motorsports
Paul (Notts)
posted on 24/11/09 at 06:41 PM Reply With Quote
The Viento is a little heavier than most sevens and I think this affects the calculations for the brake efficiency - standard sierra callipers work fine.
Good luck - only one last fence to jump and then on the road
Paul
DRC INDY 7
posted on 24/11/09 at 07:24 PM Reply With Quote
willwood handbrake calipers seem to be crap mate had them on his stylus could not get a decent handbrake with them sold them on and fitted sierra rear calipers instead
Puddle Dodgers Club
SteveWalker
posted on 24/11/09 at 07:44 PM Reply With Quote
Although my current car is fine, the first two cars I had with rear discs had terrible handbrakes - I much prefer drums for this!
adithorp
posted on 24/11/09 at 08:06 PM Reply With Quote
The willwood calipers are short of leverage on the handbrake. I got around this by fitting a secondary lever in the tunnel which increases the mechanical advantage.
http://i189.photobucket.com/albums/z282/adrianthorp/handbrakelinkage002.jpg
I'm not 100% happy with the first cable section pulling at an angle but it was easier than re-doing the cable ancorages and in practice works OK. I passed SVA easily with it and I've got a very nice handbrake that holds with little effort on steep hills and has good feel.
adrian
ps. If your using the willwood smart pads, switching to Mintex1144 pads might be enough to get you through.
[Edited on 24/11/09 by adithorp]
http://jpsc.org.uk/forum/
AdrianH
posted on 24/11/09 at 11:24 PM Reply With Quote
Sorry to hear the news, brakes are one thing we can not test without going to a MOT garage even then not everything can be tested. The idea of a second link sounds good if it can be done. Have to see what rally design comes up with.
Good luck
Adrian
Why do I have to make the tools to finish the job? More time then money.
Brommers
posted on 24/11/09 at 11:47 PM Reply With Quote
Yep. I fitted a pulley which doubles the mechanical advantage, and extended the handbrake lever. The pulley system is here on my website.
HTH
Dan
