Northy
posted on 12/4/04 at 09:12 PM |
Dash pictures
Right guys, looking for a bit of inspiration / ideas for this one, can people post pictures of their dash and / or dash pictures of layouts they like
please?
Graham
posted on 12/4/04 at 11:52 PM |
Our dash...
Just put ours online...
Looking better everyday!
wicket
posted on 13/4/04 at 11:22 AM |
Graham
Pic of ours in the photo archive. Its built up from sealed mdf with SVA 19mm rad on the bottom edges, covered with expanded vinyl. Fits behind the
flange on the scuttle with bow shaped trim piece covered in the same material to cover the scuttle flange. No fasteners show. Indicators are hidden
until lit.
Eric
Fifer
posted on 13/4/04 at 11:31 AM |
Pic of mine in my archive (not installed)
Crazy Jay
posted on 13/4/04 at 11:46 AM |
Sorry for changing subject, but does any1 know if mk sell carbon dashes?
For my interior im gonna buy a sheet on 2mm Carbon fibre to cover the trans tunnel, with milled out rounded squares on 5mm alu to surround the
gearstick, handbrake and key, starter button. With the carbon dash and R1 clocks mounted from behind like hellfires (Amazin dash by the way)
Jonte
posted on 13/4/04 at 11:53 AM |
quote: Originally posted by wicket
Graham
until lit.
Eric
Nice dashboard, looks great.
Do you have more detailed pics?
Click it
wicket
posted on 13/4/04 at 01:12 PM |
Jonte
I have a few more, I will post them tonight if possible.
steve m
posted on 13/4/04 at 01:19 PM |
For those that have seen my car this will/should make sense, for those that have not, you have to imagine
My dash is made from ply wood, covered in 1/2 foam and then vinyal over the top
the scuttle frame is about an inch inside the alui scuttle cover (ie the shiney bit that you see)
the dash is then placed into the void, and as it is slanted forward it stays there by its own device, on the sharp edge of the alui I have put some
fancy U shaped edgeing, that covers that sva unfriendley sharp edge. and also by magic (careful design) when the U edgeing is pushed into place the
dash board is clamped in fairly tight, there are no screws or fastenings holding the dash in place
steveImage deleted by owner
posted on 13/4/04 at 01:36 PM |
Carbonfibre Material
I believe MK do sell the CF stuff to which you refer Jay... give them a call. Or email them...
Nice dash's all around...
[Edited on 13-4-04 by Hellfire]
Jasper
posted on 13/4/04 at 01:54 PM |
Here's mine, slightly modified for SVA (digidash flush, central metal switched removed, black plumbers tubing used for bottom radius which
actually looks good and will be let after SVA)
BTW - beautiful job Hellfire.
![](/galpreviews/a100529-dscn0145.jpg) ![Rescued attachment dscn0145.jpg](/gallery/a100529-dscn0145.jpg) Rescued attachment dscn0145.jpg
locoboy
posted on 13/4/04 at 02:33 PM |
The main clock cluster is mounted in ally then the mdf is going to be covered in black vinyl - bit of imagination required at the moment to visualise
it but it will look ok i think. the warning lights are going in the curved section mounted in the same way. isolator on the left and fuel and volt
meter on the right of the wheel.
![](/galpreviews/ally dash blank inc clocks.jpg) ![ally dash blank inc clocks](/gallery/ally dash blank inc clocks.jpg) ally dash blank inc clocks
![](/galpreviews/mdf and ally dash blank.jpg) ![mdf and ally dash blank](/gallery/mdf and ally dash blank.jpg) mdf and ally dash blank
[Edited on 13/4/04 by colmaccoll]
Locoboy
steve m
posted on 13/4/04 at 02:43 PM |
I feel a bit left out now !!!
my dash is "conventional"
steve
Jasper
posted on 13/4/04 at 03:36 PM |
Colmacoll - very TVR looking - nice ![](/images//smilies/wink.gif) ![](/images//smilies/wink.gif)
zetec
posted on 13/4/04 at 04:08 PM |
Pic on archive. Set up works OK, but suspect MK2 will be tried soon as things change when you get on the road! Too busy trying to avoid everyone else
who now appear to be driving in slow motion to watch dials. Bigger shift light would be good, then forget rev counter, forget speedo as you will
always be over the limit.
posted on 13/4/04 at 04:40 PM |
Crikey Col...
MASSIVE pictures!
Does look cool tho'
locoboy
posted on 13/4/04 at 05:33 PM |
sorry chaps, i didnt check my post, i just posted and ran! - had things to do. had a v. productive day today, was outside at 9.00 am drilling and
filing the holes in the ally for the dash, sanded the cut outs on the MDF dash blank, PVA'd the black vinyl onto it, then followd up with
painting the chassis (when the sun got round to it about 11.00), put pedal box back together on F27, fitted new top coilover mountings to the front
pair on my F27.
you have to make the most of this weather when you dont have a garage! Shame my long bank holiday weened is now over though
Locoboy
wicket
posted on 13/4/04 at 07:30 PM |
Jonte
Few more pics of the dash & trim in photo archive
Martin Sports Car
posted on 13/4/04 at 11:45 PM |
wicket
GOOD WORK THAT YOU HAVE THERE
Jonte
posted on 14/4/04 at 07:16 AM |
Jonte
Nice photos....now I know what to do next winter to replace the dash I´m making now
Click it
Alistair Mc
posted on 14/4/04 at 08:25 AM |
dash pics
I like whats been done with all the posts. Have posted pics before, but here they are again, vynal covered mdf (seats recovered capri recaro)
I like the aloy
Fifer
posted on 14/4/04 at 09:21 AM |
Europaspares sell the carbon sheet (and real stuff also) Luego also sell the dash panel pre shaped for scuttle £50.00 I beleive
Fifer
Fifer
Fifer
Fifer
posted on 14/4/04 at 09:22 AM |
Fifer
posted on 14/4/04 at 09:26 AM |
OK, OK, we hear. Are you on commission ? Or are you just getting your posting count up? ![](/images//smilies/bigsmile.gif)
[Edited on 14-4-04 by Hellfire]
Lightning
posted on 15/4/04 at 08:20 AM |
I got carbon fibre rolled at the bottom with 20mm dia roll.
Simple but quite effective and not bad for £20. Reused bike gauges (except fuel)
![](/galpreviews/a100984-Dash 002.jpg) ![Rescued attachment Dash 002.jpg](/gallery/a100984-Dash 002.jpg) Rescued attachment Dash 002.jpg
