posted on 13/12/09 at 01:32 PM |
Check your chassis's
As some of you know I'm not too happy with the powder coating on my car which has an old Luego chassis . Have just spent the last few weekends
stripping the car down so that I can sort it out and have found the problem is even worse than I thought. The powder coating is pulling off in sheets
and the chassis under the coating is badly rusted. Going to get it shot blasted and use something like POR15 . Don't know if this problem
affects any newer than old Luego chassis's but worth checking especially you guys that took advantage of old Luego's show deals where they
powder coated the chassis for free. Suspect had the chassis's been shot blasted before powder coating there wouldn't have been a problem
MakeEverything
posted on 13/12/09 at 01:37 PM |
oh dear. Sorry to hear the problem, and hope its not terminal.
This identifies a good example of something looking good, but its functionality (or reality) is somewhat different.
Although powder coating is a nice finish, it needs to be done properly, and im always a fan of red oxide and a brush, with a durable top coat on any
metal if it needs it. At least you can inspect the metal as you paint it, and you know the coating is making contact directly.
Kindest Regards,
Richard.
Neville Jones
posted on 13/12/09 at 02:06 PM |
My locak powder coater won't put a coating on unless the item is zinc pasivated first, for for precisely the reason you have.
If you can find a product called 'Galvafroid', then it can't be bettered. Next is Zinc182.
nitram38
posted on 13/12/09 at 02:26 PM |
I took loads of stick for brush painting the MotaLeira with epoxy 121 paint, but I don't have to worry about stone chips or rust and u
can't tell if I re-touch the finish.
I went this route after all the moaning on the atom cub forums
Project7
posted on 13/12/09 at 03:35 PM |
There are areas on mine where the powder coating wasnt great, but overall its ok, but i havent purposely tried to remove it.
When did you purchase your chassis? Was it whilst Grant was running Luego?
HAL 1
posted on 13/12/09 at 03:48 PM |
my own ten year old chassis came powder coated and was flaking off so i took that to be blasted, the galvafroid is
excellent stuff if a little pricey, £65 for 1.9 ltr,
i used zinc phosphate etch primer then one coat of oil based undercoat then two coats of oil based gloss, first red then black, reasoning being that
if i could still see red i hadn't coated it all over with second coat
plus it's easy to touch up any scratches if needed, it's the first coat/primer that's important
posted on 13/12/09 at 04:32 PM |
Was when Grant was running Luego when they were still in Ramsey Heights probably about 7 years ago. Beware any signs of "bubbling" as
it's a sign of rust under the coating. Will check out Galvafoid, thanks for the tip. Mel
Project7
posted on 13/12/09 at 04:50 PM |
Hmm I purchased my chassis in 2003 so probably the same powder coating company - I'll make sure i keep my eye on it, Thanks Rusty.
hector
posted on 13/12/09 at 05:59 PM |
Luckily i bought my chassis in 2005 in bare metal and brushed red oxide primer and filler primered then gloss black enamaled and it is still excellent
and easily touch upable!
kenton
posted on 13/12/09 at 08:22 PM |
Before i started my build i had the old powdercoat blasted off, then hot zinc sprayed before re powdercoating. £300 well spent!
kenton
repper
posted on 16/12/09 at 07:21 PM |
i got mine of Grant back in AUG 2006 and i got the show offer of the free powder coating i will admit its not the best job ive ever seen by a long way
ie very dull in places but ive not noticed any bubbling any wear, i'll go have a good look over it at the weekend as its still in the build
stage its not seen any rain yet but thats not to say the chassis didn't before it was power coated cheers for the heads up.
stevegough
posted on 19/12/09 at 09:17 PM |
Maybe you need to think about changing your username - after all it looks like the problem isn't just confined to the family jewels !!
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Seriously though, I bought a second - hand unstarted project which turned out to be a Luego Locost - the powdercoating was rusty and flaking, also all
the edges of the brackets and any other flat bits eg. the wishbones were sharp and unfinished.
The first job I did was to file these edges down then get it shotblasted and powdercoated. Lots of pics in my archive. This was all at the end of
2008. The new powdercoat job was a bit thick, but is good quality. I think the locost was sold between 5 and 7 years ago (but I don't know) so
it was almost certainly back in Grant's days.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
richard thomas
posted on 21/12/09 at 07:10 PM |
I can certainly vouch for the quality of Steve's new powdercoat - lovely!!!!
wilkingj
posted on 29/12/09 at 11:47 AM |
Old Luego, didnt do much with the chassis before powder coating.
I have the same problem, at the moment I just flake it off, and paint up.
When I do a back the to chassis rebuild, it will get a sandblast and a proper coating.
As said so many times before, the final finish (of any type of surface) and its quality its down to PREP PREP and MORE PREP.
There is nothing wrong wiht the Luego powder coating. Where the chassis has been ground near welds etc, the coating is stuck like Sh*t to a blanket!
IMHO Its just the chassis was not properly prepared.
This has been mentioned to all subsequent owners of the company. Hope they have taken notice.
At the end of the day its a commercial decision they take. Its a pity they didnt make a quality judgement first.
My chassis is 4 years old with 3 years on the road (and some it is in pretty wet weather![](/images//smilies/sad.gif) ) Its not bad, just annoying when bits flake off.
Galvafroid is excellent paint. Its Zinc Rich. You will understand why its £69 a can when you pick it up and feel the weight
I use it on my Landy and on my Galvanised radio mast. Expensive... but Very Good.
Again... make sure you do the prep properly first, as its expensive paint and you dont want to waste it!
Rusty... McKays on East road sell it.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 29/12/09 at 09:23 PM |
Car is now stripped down to the bare chassis ready to take to get it shotblasted . Have been looking at various treatments but haven't decided
what to use yet , possibly POR15 or Galvafroid. Will not be powder coating again that's for sure
Dave Bailey
posted on 30/12/09 at 04:53 PM |
I had mine blasted then 50 micron hot zinc sprayed and two pack epoxy coated... It is the dogs....
Dave B
Andybarbet
posted on 20/1/10 at 08:47 PM |
Due to things that i wont mention on here, its now getting close to me starting the build finally after quite some years.
Now i picked up my chassis the same time as Geoff Wilkin.
Im now wondering about this powdercoat problem, i really need to know how much it will cost to get the powdercoated chassis blasted before i start my
build, the money will set me back timewise but i dont want the coating chipping off once ive started/its on the road.
Could someone give me a clue on blasting costs ? if i do get it blasted, i will paint it myself afterwards but i would like it primered straight after
blasting.
Also, whats the cost of the hot zink stuff or other decent base coat options ?
Sorry for all the questions but if its too expensive i may just have to stick with the powdercoat thats on it - it looks great after 4+ years but it
has been in dry storage so hasnt seen any weather yet.
Other option is wire brushes in angle grinder but not sure i can face that but i do have an offer of help from Rich (makeeverything) which is really
good of him.
Cheers Andy
posted on 20/1/10 at 09:04 PM |
Hi Andy, I've been quoted £1.10 per minute for shot blasting but he did advise me that powder coating is a bitch to get off when blasting for
some reason which is why I'm using paint stripper and scrapers to get the worst of it off. Have found some paint strippers to be better than
others , got some cheap stuff (£19 for 5 lts) from Toolstation to be pretty good but if you use it make absolutely certain you don't get any on
exposed skin . IT BURNS! Hope to finish stripping this week end and get it to the blasters so it's ready for collection the following Saturday.
Andybarbet
posted on 20/1/10 at 09:18 PM |
Cheers Mel, sounds like a bit of a blank cheque though ?
Problem i have is that if its a couple of hundred quid, that will put me back 6+ months just trying to get the cash together - things are tight at the
mo
Im a patient guy but ive waited ages so far, bit of a hard decision to make.
Ive got plenty to get on with , without starting to fit bits to the chassis so maybe i will sit tight for a while and see if cash flow improves.....
stevegough
posted on 20/1/10 at 09:57 PM |
My shotblasting and powdercoating was done by Flare in Warrington - maybe a bit far for you, Andy? However, to give you some Idea of cost, they
charged me a very reasonable £220. (this was dec 2008).
Having said that, do not underestimate the importance of rounding off the sharp edges - powdercoating doesn't like them. - This job I did
myself before taking it to warrington.
Luego Locost C20XE.
posted on 25/1/10 at 09:11 PM |
Finally managed to get the powder coating stripped off ready to get the chassis to the shotblasters. Just to show how bad it
is.![](http://locostbuilders.co.uk/upload/a1083566-IMGP0266 (800 x 600).jpg)
stevegough
posted on 25/1/10 at 09:31 PM |
Yikes! its worse than mine was!! ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
Good luck, Rusty (Chassis)-sorry- Nuts.
Er - you're not getting paint stripper on your tyres or alloys, are you?
[Edited on 25/1/10 by stevegough]
Luego Locost C20XE.
Andybarbet
posted on 25/1/10 at 11:12 PM |
OMG ! i think i need to get saving up to strip mine off before i build after seeing that Mel, good luck with the blasting mate.
Andybarbet
posted on 6/2/10 at 07:10 PM |
Any news rusty ? how did the shotblasting go ???
posted on 6/2/10 at 11:19 PM |
Shotblaster hasn't had a chance to do it yet but hope to get it back for next week end. Also hope to sort out some heating for the garage by
then as POR15 would set below 10 degrees. Will keep you posted.
