MakeEverything
posted on 20/12/09 at 01:19 PM |
Making an Exhaust....
Im looking for a cheap supplier of 2" steel tube (mild or stainless) to make up an exhaust and manifold once the prototype is finished and
tested.
Ive looked onEbay, and the pre-bent pipe and tube is quite expensive, and miles away. Im looking for somewhere local, and the nearest ive found so
far is Luton for the stainless bits.
I need the mild steel bits for now, to make up the prototype, so any offcuts or scrap would do as long as its 2".
Ive thought about going to ATS to see if i can scrounge an old 2" system from their skip, but there arent many cars on the road that use
2" exhausts as standard??
Kindest Regards,
Richard.
marcjagman
posted on 20/12/09 at 01:27 PM |
Why not try someone like Andrew Pages, or even Larkspeed. Thought about using that flexible stuff? Straight pipe for a 2 metrs lenth comes in at
around £15, bends are between £3-£7 each.
MakeEverything
posted on 20/12/09 at 01:32 PM |
Ill have a look, Thanks.
I didnt want to use the flwxible stuff, as i wanted it to be presentable as well. When im finished, im hoping to have the engine bay in show
condition. Also, the objective of making a custom manifold is to ensure they are the same length and free flowing. Flexi pipe isnt smooth inside i
think.
[Edited on 20/12/09 by MakeEverything]
Kindest Regards,
Richard.
MakeEverything
posted on 20/12/09 at 01:45 PM |
Larkspeed and Andrew Page arent what im looking for.
Im looking for someone that will supply just plain tube, so that i can cut and weld into the correct length and size.
Ive got some local firms i use regularly, so ill try them on Monday, but they specialise in sheet metal engineering rather than tube.
Kindest Regards,
Richard.
hillbillyracer
posted on 20/12/09 at 02:26 PM |
There are plenty cars that use 2"ish exhaust tubing, many turbo diesels run that kind of size if you can get some scrap sections from ATS, Thick
Fit etc to do you mock up before you spend the real money on stainless.
rickys2000
posted on 20/12/09 at 03:42 PM |
try good fabrications in long crendon just outside of aylesbury. I know they can and do supply materials only, not sure about costs though
Volvorsport
posted on 20/12/09 at 04:38 PM |
how much do you want ?
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 20/12/09 at 04:52 PM |
Check out your local motor factors they should be able to help
MakeEverything
posted on 20/12/09 at 06:40 PM |
Probably just a couple og metres, and a few bends. An old header would do with a centre section.
A guy at work is letting me have his old scooby centre section, just need a few more bits to play with and cut.
Kindest Regards,
Richard.
MakeEverything
posted on 20/12/09 at 06:41 PM |
Not with a "Locost" philosophy they wont....
Mine (Autorange, The Oval) are really good, but he doesnt do much for nothing! - But then he does own the business....
Kindest Regards,
Richard.
Dingz
posted on 20/12/09 at 09:42 PM |
I think I paid under a tenner for 2m of 2" tube from my local factors.
went on and on.
Chippy
posted on 20/12/09 at 11:16 PM |
For your stainless these people are pretty good for both straight and bends. HTH Ray
Exhaust clicky
MakeEverything
posted on 21/12/09 at 12:06 AM |
Exhaust clicky
Cool, Thanks. Loving the idea of the GP stylee springs to hold it all together. Hadnt thought of that before.... hmmmm....
Kindest Regards,
Richard.
iank
posted on 21/12/09 at 11:15 AM |
For stainless tube/bends the cheapest route is to buy from a supplier that does hygienic stuff for dairies. Buying from automotive places is much
more expensive.
NS Dev recommends this place http://www.allstainlessltd.co.uk/
Anonymous
Chippy
posted on 21/12/09 at 11:08 PM |
2" Pipe from "Allstainless" 48.02 + VAT
2" Pipe from "OJZ" 15.25 + VAT, I think I win on that one, Cheers Ray
aitch
posted on 22/12/09 at 11:08 AM |
lol yeah dairy or medical tube is usually high polished inside as well as out and so more expensive than exhaust stuff that is often raw finish
thanks guys this thread has been of great interest to me for suppliers for my bike exhausts
aitch
