Author: Subject: steering set up?
daniel mason
posted on 13/1/10 at 06:58 PM Reply With Quote
steering set up?
following on from my recent posts regarding a honda s2000 as a donor,is it possible to use the honda steering wheel,column,key set,indicator stalks and all switch gear and mate it to the supplied rack?
how much modifications need to be done to make it work? cheers
rickys2000
posted on 13/1/10 at 07:06 PM Reply With Quote
Hi
Yes it is. That is exactly what I did.....Basically modified the bottom of the column to mate with the sierra triangular section to to fit the Ford based bulkhead fitting. All switchgear etc used was from the Honda. I think I have some pics in my archive, if not I have defo got some on the laptop and will add them on
Ricky
speedyxjs
posted on 13/1/10 at 08:34 PM Reply With Quote
You can use what you like. I have used as much from the donor car as possible (all the usuals aswell as wishbones, steering column and uprights)
