timcrasher
posted on 21/4/04 at 12:16 PM |
SVA Fail
Hi guys,
Took my beast for its SVA today at Nottingham. It failed on just the Lambda reading ( just too high ), and the brake bias ( which was adjusted on site
The tester was very helpful and very complementary about my car, which made the whole process alot less stressful.
All you guys going for SVA tests this week, take lots off rubber edging stuff etc as the tester will let you cover any troublesome parts as you go
through the test.
I'm off back to the MOT station tommorrow to have another play with the settings and will hopefully get retested next week!
I rang my exhaust supplier ( a well known feline branded kit maker ) for advise, because they said the exhaust system would pass, and was basically
told it was my problem and to get lost.
But a phone call to Fisher sports cars was the total opposite. Helpfull advise and a pleasant manner even though I dont own one of his products. Top
man!
Good luck to the rest of you
Tim![](/images//smilies/tongue.gif)
posted on 21/4/04 at 12:53 PM |
Good products and good attitude go together.
Nick Davison
posted on 21/4/04 at 01:08 PM |
What was the problem with the brake bias? And what is your opinion of the Nottingham examiners, I have to use them sometime?
Nick
timcrasher
posted on 21/4/04 at 02:41 PM |
SVA Fail
Hi Nick,
The brake bias adjuster I fitted just wanted an extra turn as I had to much rear bias.
The Nottingham SVA inspectors were fantastic and tried their best to get me through first time. We spent about fourty minutes adjusting the mixture
etc, but just couldn't get the reading low enough. The tester looked almost as disappointed as me.
Lightning
posted on 21/4/04 at 03:53 PM |
You say adjusted the bias, do I take it that it was a bias bar and if so did you put in roll pins?
As you probably gather I have a bias bar and will soon be applying for SVA
ChrisBradley04
posted on 21/4/04 at 04:48 PM |
Tim,
If you can't get lamda down but CO & HC are fine, then I would check for an exhaust leak. In the end my emissions failure was cured by using
a pot of 'GunGum' on the exhaust joint
Sorry if I am teaching my granny....and all that.
Regards
Chris
www.fisherfury.com
posted on 21/4/04 at 05:05 PM |
Just had a high lambda fail on one of my other cars, suspecting the exhaust was drawing air I looked I found a pin hole in the welds in the exhaust
down pipe.
spunky
posted on 21/4/04 at 05:06 PM |
Timecrasher- you have U2U
Markp
posted on 21/4/04 at 05:17 PM |
I used Nottingham almost a year ago (how time flies!!!!!!!!!)
The examiners were very helpful, put you at ease and want the car to pass.
A good experiance at the time.![](/images//smilies/bigsmile.gif)
mark
timcrasher
posted on 21/4/04 at 05:58 PM |
SVA FAIL
Thanks for your suggestions guys.
I did check for leaks. but the examiner said that I needed to get more air bled into the exhaust to get a lower reading.
Steve,
I have a rotary bias valve fixed with a roll pin. I just needed to remove the roll pin, turn the knob and refit another pin.
Gonna experiment with the air valves in the cam cover tommorrow at the MOT station to see if that makes any difference.
Tim
posted on 21/4/04 at 06:33 PM |
Steve,
snip
Tim
High lambda alone usually caused by too much air -- either due to a weak mixture or more usually a pin hole somewhere in the exhaust down pipe.
See http://www.bobmckay.co.uk/p_emissions.html Basic fault finding for advanced emission test failures --point 5
Mk-Ninja
posted on 21/4/04 at 06:53 PM |
Hard luck Tim hope you get it sorted
The emissions is my main worry. Dont thing Im going to sleep tonight, mind you Ive got to set off at 5:30 so its not worth going to bed antway .
On my MOT the CO was very low but the HC was marginal, how do you lower the HC without affecting the CO too much.
Hope Im not talking gibberish here but cant think straight at present.
I'm sure I've got one, just don't know where I've put it
timcrasher
posted on 21/4/04 at 07:57 PM |
Sva fail
I will have another go with the mixture settings then.
The exhaust is deffinately not leaking, so I will richen things up, as the co and hc readings were very low.
Gordon good luck tommorrow. I had to get up at 5am. I didn't sleep at all, so I know what you're going through. But it will be fine.
Tim
ChrisBradley04
posted on 21/4/04 at 09:47 PM |
Gordon,
If CO and lamda were all in range, but HC is marginal then make sure that your cat is HOT as possible for the test. The hotter the cat the better it
works. I did a few fast laps of the SVA centre, putting the engine under load , just before doing the test. I had my pipes glowing red
The worst case scenario is a bigger cat, which can be rented cheaply if required.
Good luck tommorow.
Regards
Chris
[Edited on 21/4/04 by ChrisBradley04]
