stupott901
posted on 26/1/10 at 08:04 PM |
MOT and age related plate
hi there
i have just tried to tax my MK indy online and it has refused the application saying it cant find MOT info
it is age related plate J reg passed its sva in Aug 09 and registered the same day,
do i need a mot ?????
i apologise if this has been asked loads of times all ready
many thanks stu
Humbug
posted on 26/1/10 at 08:07 PM |
It has been asked many times!
Take the documentation to the post office and show them the V5C to prove it is less than 3 years old... assuming that DVLA got it right the first time
and put Aug 09 as the date of first registration ![](/images//smilies/wink.gif)
stupott901
posted on 26/1/10 at 08:11 PM |
there is a problem there date of first reg is may 1992 bugger
on the special note it says :
sva issued 27 08 09
rebuilt- assembled from parts some or all of which were not new
im i still stuffed??
Humbug
posted on 26/1/10 at 08:17 PM |
Sounds like DVLA made a mistake. I would contact them and say (politely) that you think it's a mistake because it was not rebuilt but a kit car.
Since it is age-related and not the original donor reg (unless it is?), then it is not the same vehicle, therefore 27 08 09 should be recorded as the
date of first registration.
Good luck with DVLA... it will depend who you get.
Davg
posted on 26/1/10 at 09:36 PM |
Stu
as Humbug says above usual DVLA! Your car did not exist in 1992 and when first registered in 2009 that should have been entered as sug albeit some
donor parts were used.
Get in to DVLA office to re tax and bite your lip politely asking them to correct
DATE OF FIRST REGISTRATION! been down that road twice wiff em and sorted out once you explain.
Warning to all check the registration carefully when you get this back after initial first registration.
cheers D
mad4x4
posted on 27/1/10 at 09:01 AM |
Try online - You may find it will work that way
Scot's do it better in Kilts.
stupott901
posted on 27/1/10 at 04:16 PM |
Well after an hour on the phone to DVLA they still saying that date of first registration (1992) is right but they said it does not need MOTing for 3
years
they said try the post office if not go to thier office in bristol, which is a pain as they only open week days and i work all week
at least it is a bit of a result
