germanguy
posted on 21/6/10 at 01:30 PM |
trying to kill itself
been driving my toy over the weekend and have kinda noticed a smell onse in a while
didn`t think anything off it until battery warning light comes on and voltage fluctuates around 11 to 12 volts
hrmm lets have a look i thought quick word with mark ....thanks again mark.... and off comes the voltage reg again trying to set fire to itself darn
thing
Bluemoon
posted on 21/6/10 at 01:44 PM |
Looks likebad connection overheating (i.e. high resistance)...
germanguy
posted on 21/6/10 at 02:18 PM |
iether that or voltage reg has killed itself have ordered a new one just in case
Bluemoon
posted on 21/6/10 at 02:50 PM |
Maybe likely still to be a poor connection, corrosion on pins loose wire etc. The voltage regulator deals with quite high currents you don't
need much resistance to to generate a lot of heat.
Dan
gingerprince
posted on 21/6/10 at 02:58 PM |
Mine did that. Twice. Once ate the block connector (and hosed itself), then melted the blade connectors I connected the replacement rectifier with.
It's now soldered in and been fine ever since.
loggyboy
posted on 21/6/10 at 04:22 PM |
Bad earth.
germanguy
posted on 21/6/10 at 04:36 PM |
moved the lacation to within the engine bay rewired the darn thing and presto it does kinda work well at least until my new one arrives
