expatkiwi
posted on 8/7/10 at 09:56 PM |
Is there a plumber in the house?
I have probs with my heating.
The heating is not on yet all the rads downstairs are.
cheers
Brian
I have decided to call my Westfeild "The Caterhammer" Hopefully it will
posted on 8/7/10 at 09:57 PM |
Diverter valve has gone south. Typically it's the motor and you can usually change them without changing the zone / diverter valve.
austin man
posted on 8/7/10 at 10:02 PM |
same happened to mine , diverter valve generaly a simple fix I bought a new on locally 15 minutes to fit the worst part is draining the sustem below
the valve then the filling. If it is the valve a simple check is to run the hot water and see if the rads get hotter thats what happened to mine
jase380
posted on 8/7/10 at 10:04 PM |
as Benb says, had the same problem myself a couple of years ago, your local plumcentre will sell the required springy gubins thats packed in.
MakeEverything
posted on 9/7/10 at 06:46 AM |
It sounds like your three port valve.
Can be either the motor or the valve itself. You should be able to operate the valve manually to see if its seized. If not, then just get a new
actuator.
Kindest Regards,
Richard.
adam1985
posted on 9/7/10 at 07:34 AM |
What system is it a combi or conventinal boiler on y plan s plan ?
Jasper
posted on 10/7/10 at 12:16 PM |
What, plumber and doctor?? That's got to make for some interesting call outs
posted on 10/7/10 at 12:30 PM |
Drain Doctor vans are out round here all the time
