*AL*
| posted on 21/1/11 at 11:25 PM |
MAC#1 engine oil level R1?
Hi all, already posted this in the BEC section then noticed there is a MAC section! Awesome, question is when cold where should the oil level sit on
flat ground in the oil sight glass?R1 engined. Thanks in advance. Al.
bigrich
| posted on 22/1/11 at 12:03 AM |
Generally with an R1 you need to fill as normal to the full line then add a small overfill of approx 250ml to help combat surge and the oil level lamp
being activated.
R1's do seem to use a bit of oil if used for prolonged high revs even in the bike , so check it regularly and when it drops to the full line
then add your 250 ml again.
HTH Rich
you can always give Mark or Col a ring just to confirm.
bigrich
| posted on 22/1/11 at 12:07 AM |
Just spottdr the other post and piccys, car was used in the first track and race car magazine and was built for Darren Terry if my memeory serves me
correctly.
*AL*
| posted on 22/1/11 at 12:11 AM |
correctly.
Yes i think you are correct, i have paperwork showing Darren Terry. I also have the 2004 magazine feature showing my car. I'll be topping up the
oil first thing in the morning just to be sure.
*AL*
| posted on 22/1/11 at 12:13 AM |
Here you go.
bi22le
| posted on 22/1/11 at 12:35 AM |
yep as said above fill it above the glass. Stops any problems caused because the engines does not have centralpetal forces acting on the oil. Good
luck with the MAC 1 they are nice chassiss and the company is nice to deal with.
Please read my ring story:
