tims31
posted on 1/9/11 at 01:30 PM |
Chassis number and scrapping the donor
Ok, a little help required before my donor goes to the big scrap yard in the sky.
I have taken the VIN plate off the slam panel (Sierra Saph) but I know there is at least one other place on the car where the chassis number is
stamped but I’ve looked in the usual place and can’t seem to find it, anyone have an idea where it is located please?
Also, after reading the comments about scrapping off the donor and keeping the V5 docs to obtain an age related plate what is the best way of
achieving this? Can it be disposed of through a scrappy or can it only be done by selling as scrap metal?
I did speak to DVLA on the phone and they said send in the V5 doc with a covering letter stating that it was going to be used as donor and that would
be ok but they didn’t seem too sure.
Any help gratefully received....
Build: http://www.martinsfurybuild.co.uk/
Mr Whippy
posted on 1/9/11 at 02:26 PM |
I think the chassis number is on the floor under the carpet next to the drivers door
poss under a plastic cover
[Edited on 1/9/11 by Mr Whippy]
big_wasa
posted on 1/9/11 at 05:17 PM |
I can tell you of a good scrapie that will pick it up or where you can weight it in if needed ![](/images//smilies/wink.gif)
clairetoo
posted on 1/9/11 at 07:15 PM |
Keep the log book - theres no need to send it to DVLA - just remember to have it in your name , and keep the SORN up to date while building .
As far as I know , the shell can just be scrapped - since it has no identity that should be easy enough .
Its cuz I is blond , innit
Claire xx
Will weld for food......
tims31
posted on 2/9/11 at 10:41 AM |
Thanks for all that,
Need to have a hunt around to find all the chassis numbers now.
big_Wassa: - will speak to you tonight about the srappy when I drop your stuff off.
When I spoke to DVLA they said just write a letter and that would cover it but would much rather keep the V5 and just SORN every year, safer that way
to get an age related plate
nogger827
posted on 7/9/11 at 10:04 PM |
scrapping
i know somebody not far from you that would collect it and he wouldnt need the log book let me know if you want his no mate
tims31
posted on 15/9/11 at 08:31 PM |
Thanks Nogger that would be good.
Sorry for the lateness...been a bit busy at work.
Post here or U2U if you'd rather
tims31
posted on 27/9/11 at 05:03 PM |
Hey Nogger,
Any chance you can let me have that guys number. I have U2U'd you but no reply..
b14wrc
posted on 6/10/11 at 11:23 AM |
I sorn'd mine and cut the car up into very small pieces and took it to the metal man.
As far as the DVLA is concerned, its off the road. I am not sure if i will be able to use its identity to re-register the locost - from what i have
read, but if i can't, i will just send the V5 back saying its now scrapped.
20vt powered rear engined locost
DixieTheKid
posted on 7/10/11 at 10:50 AM |
I stripped mine of all parts and sent it down the scappy and weighed it in (£150 filled with crap charrr chinnggg.....) Didnt even think to take the
plates or chassis numbers off.
Sadly i didnt get the logbook when i purchased the car (he couldnt find it, seemed genuine enough though), i only applied for it the other day but
scapped the cars months ago. Ill let you know what happens.
Chris
COS IT'S Worth IT
posted on 7/10/11 at 10:54 AM |
The chassis number is stamped on the floor just down the side of the drivers seat next to the door. I cut mine out, took the vin plate off and kept it
sorn. I handed it in when I registered and visibly witness the young lass tear it up and put it in the bin
Checking on the dvla vehicle check it still shows as liable!!
DixieTheKid
posted on 14/10/11 at 10:35 PM |
Chris
Got my logbook today! So in my case it didnt matter, Huntleys just crushed it regardless! Yay!
COS IT'S Worth IT
