ss1turbo
posted on 30/10/11 at 11:01 AM |
Upgrading trailer to braked axles
When I bought my trailer, I didn't even think about looking at the brakes on it - until I realised it doesn't have any... Aside from
throwing several hundred pounds at it via Indespensions website, anyone got any ideas?? Looks like its got their "all i one" standard hub
units (its a twin axle), a sliding hitch and a handbrake leverbut nowt else....
Long live RWD...
owelly
posted on 30/10/11 at 11:19 AM |
If you already have the sliding hitch with braking facility and if your hubs have drums and you have backplates fitted, then it should be a case of
fitting shoes and linkages.
http://www.ppcmag.co.uk
ss1turbo
posted on 30/10/11 at 11:29 AM |
Therein lies the problem - none of the hubs are the braked variety (no drums etc). They look to be the old Imperial (Mini PCD) variety as well...
The original use the trailer was built for (and well built IMHO - not a converted caravan chassis job) probably meant that it was less than 750kg
laden (1930's Austin 7) - it used to be towed by a Pug 206, so can't have been a lot!
Long live RWD...
owelly
posted on 30/10/11 at 11:47 AM |
But why use the braked tow hitch if there were never brakes fitted? Is there any mounting holes on the hub carriers for Mini back plates? Would it be
possible to retro fit Mini brakes? It's not entirely legal but cheaper than fitting four new braked suspension units at mucho costo!
By the time you've bought the new braked units, cables and linkages, you may be better off buying a different braked trailer or robbong a
caravan chassis for it's axles. Post up some piccies of what you have and see what the collective can suggest.
[Edited on 30/10/11 by owelly]
ss1turbo
posted on 30/10/11 at 11:53 AM |
Have just been looking at ebay for axles - a s/h caravan one (suitably rated) with the cables is about £100 if I can find one about the right size
width which is OK. Only had a quick peek at the axles on mine, and they don't appear to have any backplate mountings but will grab a pic and
put it up.
Might be cheaper and easier to buy another one, but this is a nice compact trailer just the right size (14ft long so fits in a lockup garage
easily)...
Long live RWD...
Neville Jones
posted on 30/10/11 at 12:21 PM |
If it's an old trailer,(it WAS built before 1992, wasn't it? 0 you can fit Mini or Metro brakes, if the hubs are
Mini/Metro. Handbrakes hooked up to the sliding hitch.
If you need to spend bigger money, you can't go past Abbey Trailers in Derby. They sell everything you want at builder prices.
Nev.
