AndyW
posted on 6/1/12 at 07:40 PM |
The big day tomorrow!
Well the time has come.....
Just got to add fuel and turn the key.
Fingers crossed for a successful "first start"
Video camera on charge....
bob tatt
posted on 6/1/12 at 07:48 PM |
Best of luck don't forget the fire extinguisher![](/images//smilies/bigsmile.gif)
Xtreme Kermit
posted on 6/1/12 at 07:50 PM |
Good luck! and +1 on the extinguisher ![](/images//smilies/smile.gif)
Stott
posted on 6/1/12 at 08:05 PM |
and don't forget to open the garage door! ![](/images//smilies/smile.gif)
posted on 6/1/12 at 08:13 PM |
Or we won't get to see the video! Sure It'l be fine
wilkingj
posted on 6/1/12 at 09:05 PM |
+1 on the safety items.
A video on here is obligatory.
Or on Youtube and a link to it. either will do.
Best Regards
Geoff
http://www.v8viento.co.uk
Simon
posted on 6/1/12 at 09:06 PM |
And make sure it's in neutral
Simon
bob tatt
posted on 6/1/12 at 09:09 PM |
Simon
Good point ![](/images//smilies/bigsmile.gif)
Andybarbet
posted on 6/1/12 at 09:12 PM |
Great good luck & if you give me a time when your going to try, i will listen out for the WOOHOOOO
Im onlyabout 15 miles from Beds so i will probably hear you !
owelly
posted on 6/1/12 at 09:32 PM |
+1 more for fire extinguisher! And don't tighten the battery terminals in case they need to come off quick!
http://www.ppcmag.co.uk
AndyW
posted on 6/1/12 at 10:17 PM |
Simon
No prop shaft attached!!!
Thanks for the safety tips guys, will post when its running!!!
AndyW
posted on 8/1/12 at 10:38 AM |
Well, update on first start. Made all checks, fuel pipes all secure.
Have good oil pressure
Got good fuel pressure, swirl pot filled, returns wroking, pumps working.
Got spark.
Got flat battery
I am using an old battery that I obtained so whilst I was doing the wiring I could check as I went along, charged it up but just not enough power to
turn engine over well with the plugs in. Im confident it will start, so just got to get a new battery then will try again![](/images//smilies/smile.gif)
tomgregory2000
posted on 8/1/12 at 10:41 AM |
So close ![](/images//smilies/sad.gif)
