Author: Subject: Handbrake dash light always on?
gregf27
posted on 21/3/12 at 08:33 PM Reply With Quote
Hi all,
The handbrake warning light on my F27 has sudenly decided to permantly stay illuminated when the handbrake is off??
Have replaced the handbrake swith and it still does it? any ideas as to the cause?
cheers
Greg
daniel mason
posted on 21/3/12 at 08:38 PM Reply With Quote
fluid level sensor?
posted on 21/3/12 at 09:26 PM Reply With Quote
Aye, brake fluid low level. Check it quick before you run out of brakes!
wylliezx9r
posted on 21/3/12 at 09:58 PM Reply With Quote
As said already check your brake fluid. The light is actually a brake fluid warning light, the hand brake is a used as a means of testing the light. There is no actual requirement for a hand brake warning.
George Best
tomgregory2000
posted on 21/3/12 at 09:59 PM Reply With Quote
Also its NOT a handbrake light!!!
The handbrake is used as a check method for the low fluid level warning light to make sure the warning light still works.
Check the fluid level
Chippy
posted on 21/3/12 at 11:18 PM Reply With Quote
But should you check the fluid level and find that its up to level, then check the wire that goes to the handbrake switch and see if it is shorting out, because all the switch on the handbrake does is put it to earth. HTH Ray
gregf27
posted on 24/3/12 at 06:59 PM Reply With Quote
Thanks everyone all sorted out -
Twas indeed - low brake fluid level!!! - it had just gone under the low mark on the reservoir.
All topped up with fresh fluid.
Thanks again troops
Greg
iank
posted on 25/3/12 at 07:17 AM Reply With Quote
<grumble>
Car manufacturers putting the brake fluid warning light test switch on the handbrake probably seemed really clever when some bright spark suggested it, but it leads to people not knowing what the light is really there for!
Wonder how many people have died because they didn't treat the light with any urgency
</grumble>
Anonymous
posted on 25/3/12 at 10:04 AM Reply With Quote
Originally posted by iank
<grumble>
</grumble>
RTFM???
iank
posted on 25/3/12 at 02:08 PM Reply With Quote
<grumble>
</grumble>
RTFM???
Given the number of people on here over the years that have made the same mistake it fails the 'bleedin' obvious test' required for consumer grade machine interfaces.
Maybe there should be a little sign that lights up saying "stop now, brake fluid low - unless you're a numpty who's left the handbrake on!"
Anonymous
