Alfa145
posted on 17/4/12 at 02:01 PM |
Suspension Setup
After my scarey trip to Blyton on Sunday and finding my back end was like it was on ice.
Any recomendations for companies that can setup my suspension to something like correct and give me some knowledge on how to then tweak it? Also what
sort of cost would I be looking at?
Yes I know I can soften this off and stiffen this up but I would like to know what I have is correct spring rates and correct wheel alignment and
correct corner weights, etc... Once I have something close I then have a decent benchmark to further tweak, as it stands I'm just guessing.
Looking for places around Chesterfield/Sheffield.
Someone at Blyton mentioned a company called Rutland or something, unfortunatley my senility has let me forget the name of the company.
liam.mccaffrey
posted on 17/4/12 at 02:05 PM |
I know Procomp are highly regarded
Build Blog
Build Photo Album
fesycresy
posted on 17/4/12 at 02:11 PM |
Procomp or Northampton Motorsport.
dunk3
posted on 17/4/12 at 02:15 PM |
Give Mac#1 (01142511016) a ring they will sort it for you , did mine well happy with it .
MikeCapon
posted on 17/4/12 at 02:58 PM |
Procomp.
They may not be next door to you but you will dealing with the best guys for the job.
And they make a good cup of tea.
twybrow
posted on 17/4/12 at 03:05 PM |
Procomp. The best money I ever spent on my car....
franky
posted on 17/4/12 at 04:11 PM |
They might be busy now the F1 season is underway
matty h
posted on 17/4/12 at 07:42 PM |
What about AW Tracksport at Horncastle.Believe a couple of people on here have used them but not done myself.
procomp
posted on 17/4/12 at 07:59 PM |
Hi
Thanks all for the recommendations. IF The OP is interested just give me a call in the workshop. Tel-01213503258.
We charge a flat £200. That includes the usual full geo setup corner weighting Dampers removed and dyno tested / balanced and spring rates tested. We
don't just give you the static settings as per a 4 wheel laser setup we also map out the camber gain Etc so you have a full setup with much more
info on what is happening to the settings during cornering also.
Cheers Matt
franky
posted on 17/4/12 at 08:37 PM |
Thats where I took mine and its handling had rave reviews from some testers.
Alfa145
posted on 18/4/12 at 01:38 PM |
Thanks for the replies chaps.
