scutter
posted on 31/5/12 at 12:57 PM |
Maths check please
I've mocked up this fuel tank in our new racecar, cuold someone please check the Maths as i've calculated it's volume as 69L
ATB Dan.
jonrotheray
posted on 31/5/12 at 01:06 PM |
that's what I make it too (69.21875!!!)
Jon
mcerd1
posted on 31/5/12 at 01:13 PM |
1m^3 = 1000l
(0.2*0.265 + 0.21*0.275) * 0.625 = 0.06921 m^3
so thats 69.2l
[Edit - miss read the dims....]
[Edited on 31/5/2012 by mcerd1]
scottfraser
posted on 31/5/12 at 01:18 PM |
yep it's 69.5625 litres
mad4x4
posted on 31/5/12 at 01:32 PM |
625 x 475 x 200 gives 59375000 mm3
625 x 210 x 76 gives 9975000 mm3
total = 69350000 mm3 = 69.35L
this is becasue 1 mm3 = 0.0000010L
[Edited on 31/505/12 by mad4x4]
Scot's do it better in Kilts.
loggyboy
posted on 31/5/12 at 02:42 PM |
I read the small dim as a 75mm, not 76mm,
so 69.218750
[Edited on 31/5/12 by loggyboy]
Mistral Motorsport
scutter
posted on 31/5/12 at 02:51 PM |
Cheers folks, with the swirl pot it's gonna be a 72L fuel tank! should be enough for a 2.5L engine during something like the Birkett.
ATB Dan.
gremlin1234
posted on 31/5/12 at 05:39 PM |
you dont say if these are internal or external dimensions,
if they are external, and you use 2mm thickness, it is about 3 litres smaller, 66.4l
