Author: Subject: Mk Full Cage & Windscreen
Bumble
posted on 13/7/12 at 09:38 AM Reply With Quote
Does anyone know (or has fitted) a windscreen to an MK with full roll cage. Given the c**p weather I'm looking into fitting a screen and buying some wet weather gear for the car?
Thanks,
Matt
PAUL FISHER
posted on 13/7/12 at 01:25 PM Reply With Quote
You can fit a windscreen to a MK with a full cage, but the weather gear, hood etc won't fit over a standard MK cage, as it was design just to fit over a standard MK roll bar.
[/img]
[/img]
Bumble
posted on 13/7/12 at 02:23 PM Reply With Quote
Thanks Paul,
Yep, I appreciate the std wet weather gear won't fit but wasn't sure on the windscreen. I presume you're talking about the Mk supplied screen but it's pretty expensive, do you know of any others that fit?
Thanks,
Matt
PAUL FISHER
posted on 13/7/12 at 02:41 PM Reply With Quote
"Mangogrooveworkshop" on here was making the frames for the Indy screens, then you just fit your own glass, not sure if he is still doing them, could be worth a U2U to him.
http://www.locostbuilders.co.uk/viewthread.php?tid=116795
