Ryan.G
posted on 8/8/12 at 09:15 PM |
Sierra drive shafts push in type problem with lsd
Evening gents,
I have a sierra 7 inch diff with 3.3 crown and have just had fitted a sierra LSD unit but upon fitting I have noticed that the push in shaft stubs I
had previously fitted to my striker no longer fit.
Looks like the LSD unit was from a bolt on type?
I'd it possible to get hold of the stubs which go into the LSD to work with the knuckles I have on my push in shafts.
Or can you get, or does anyone have any drive shafts with have push in on hub and bolt on at diff end
Thanks in advance
Ryan
AdrianH
posted on 8/8/12 at 09:26 PM |
Unless you are fitting a Quaiffe ATB lsd then all the Ford viscus LSD's had their own shafts with the nearside longer then the off-side. These
shafts were fastened internally with a C clip. So what type of LSD have you fitted?
Adrian
Why do I have to make the tools to finish the job? More time then money.
Ryan.G
posted on 8/8/12 at 09:41 PM |
Hi Thanks for the reply
It is a Ford LSD unit from a Cosworth 4x4 if i remember correctly.
Do none of the LSD accept the Sierra push in shafts?
AdrianH
posted on 8/8/12 at 09:46 PM |
I have just fitted a LSD from a 4x4 V6 to the back of my car, I assume then you do not have the original stub axles out of the 4x4 diff unit, or do
you?
I am also assuming that your car has the standard drum brakes with push is shafts.
I have done a conversion as done by a few others and modified my push in shafts to take the 100mm Lobro joint that should be on the LSD.
So a few questions do you have the original 4x4 LSD stub axles. Also you need to have 27mm diameter drive shafts.
Adrian
The only LSD unit I am aware of that takes push in shafts is the Quaiffe ATB differential.
[Edited on 8-8-12 by AdrianH]
Ryan.G
posted on 8/8/12 at 09:53 PM |
EDIT:
This is what i have
http://img.auctiva.com/imgdata/1/6/6/7/1/8/9/webimg/591305297_o.jpg.
My Shafts are push in on the hub also but i have had a rear disc conversion done
Take it need different stubs then, Anyone have any for sale
[Edited on 8/8/12 by Ryan.G]
Ryan.G
posted on 8/8/12 at 09:55 PM |
Edit
AdrianH
posted on 8/8/12 at 09:59 PM |
How was the disk conversion done, I assume it could be just the adapter plate that allows callipers to be fitted.
You need to find stub axles from a Ford 7 inch LSD. These could be hard to get on their own.
Adrian
AdrianH
posted on 8/8/12 at 10:02 PM |
A bit confusing as your picture shows lobro stub axles fitted to the diff unit, when you say push in do you mean the will just pull out of the
diff?
Are the stub axles both the same length?
Adrian
mcerd1
posted on 8/8/12 at 10:29 PM |
none of the ford LSD's can use push-in type shafts
the stubs that go into the diff are equal length on open diff's, but unequal on LSD's
so that gives you 2 options if you want to use this diff
1 - change the hubs and shafts to bolt-on ones (assuming they fit your uprights)
2 - make so hybrid shafts that are bolt-on one end and push-in the other
both have been done several times before by folk on this site - search throught the old posts and you should find lots of threads about this
norm007
posted on 9/8/12 at 08:27 AM |
This is what i have
I should have 2 x after buying a pair of bolt on shafts as I also converted to LSD and made up hybrids.
It is an easy conversion to do and I got the relevant info off here.
I will have a look later today and get back to you
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
Ryan.G
posted on 10/8/12 at 10:32 AM |
That would be perfect
quote: Originally posted by norm007
This is what i have
loggyboy
posted on 10/8/12 at 10:42 AM |
You need diesel sierra drive shafts (not sure if ALL diesels are the same) but they will allow you to use lobro (bolt on) inner CVs to connect to the
LSD and retain the standard tripod (push in) outer CVs etc.
http://www.locostbuilders.co.uk/viewthread.php?tid=93484
[Edited on 10-8-12 by loggyboy]
Mistral Motorsport
