Author: Subject: Which Rad Fan switch for C20XE engine?
gregf27
posted on 22/6/13 at 07:46 PM Reply With Quote
Just been tinkering in the garage today as I had a small water leak on my F27 C20xe ( leak now fixed ) noticed the rad fan switch didnt kick in until water temp gauge was around the 110 degrees mark!!
It has a 82 deg thermastat and that is working fine, am thinking the fan switch isnt working properly?, it usually kicks in around the 90 deg mark and the car runs happily around 80 deg during normal driving.
Was thinking of changing the fan switch , what temp range should I go for?
so far ive seen the following - 82c -68c / 88c-79c / 95c-86c / 97c-85c ( switch is M22 x 1.5mm two pin )
was thinking of going for the 95c - 86c one from Car builder solutions.
any thoughts as to which to go for?
cheers and beers
Greg
posted on 22/6/13 at 08:06 PM Reply With Quote
As long as the switch in and out temperatures are both at least 4 degrees above the thermostat openning temperature all will be well.
Intermotor 50220 92 cut in 87 cut out. cheap as chips.
RADIATOR FAN SWITCH 50220 FIAT UNO 1983-85 NEW | eBay
Fatgadget
posted on 22/6/13 at 08:21 PM Reply With Quote
Kenlow used to do an adjustable fan switch...Come to think of it are they still trading?
Ben_Copeland
posted on 22/6/13 at 08:23 PM Reply With Quote
Your lucky.. at least your radiator gets hot enough
Interesting your temperature up so high, if your fan is coming on then maybe your radiator isnt getting hot enough like mine?
Ben
Locost Map on Google Maps
Enter Your Details Here
gregf27
posted on 23/6/13 at 06:38 PM Reply With Quote
British Trident many thanks, ordered one from the bay of E !!!!
