rdodger
posted on 16/2/14 at 09:39 PM |
Alloy sump leak
My alloy sump was cut n shut by a friend but has a couple of small leaks from the welds.
I have tried some chemical metal putty stuff but that appears to be porous!
Anyone know of something I can use that's oil proof? Either paint on or putty?
JohnH
posted on 16/2/14 at 09:53 PM |
Mines the same.... Tiny tiny drip....... I can't figure out what to do. ![](/images//smilies/mad.gif)
Uphill Racer
posted on 16/2/14 at 10:32 PM |
JB weld?
http://www.jbweld.com/product/j-b-weld/
umgrybab
posted on 16/2/14 at 10:48 PM |
I've seen this stuff used on the seams of homemade petrol tanks to prevent seeping. Worked a treat.
http://www.amazon.co.uk/gp/aw/d/B001U7EJVS/ref=mp_s_a_1_1?qid=1392590687&sr=8-1&pi=AC_SX110_SY165
Scuzzle
posted on 16/2/14 at 11:34 PM |
A smear of the grey Dirko seal (not the red stuff, it's not so good) will do the trick. This is the stuff that VW use to fit sumps, water and
oil pumps etc. Smear it on and leave it to set or smear it on and push a small metal plate over it and use the Dirko seal to bond it over your leaky
area and it will sort it.
http://www.ebay.co.uk/itm/DIRKO-ELRING-VW-AUDI-SEAT-SKODA-ENGINE-SUMP-SILICONE-GASKET-SEALANT-D176404A2-/251396526765?pt=UK_CarsParts_Vehicles_CarPart
s_SM&hash=item3a886692ad
ashg
posted on 17/2/14 at 08:46 AM |
get someone good to weld it :-) if you want to stick it in the post i can sort it for you, i owe you a favour.
[Edited on 17/2/2014 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
John P
posted on 17/2/14 at 09:15 AM |
Never tried but how about this?
http://www.loctite.co.uk/sea/content_data/93808_290EN.pdf
John.
rdodger
posted on 17/2/14 at 09:23 AM |
Thanks Ash
It was Jim that welded it ;-)
I will try another bodge. If that doesn't work Joe has offered to do it and he is quite local.
ashg
posted on 17/2/14 at 10:57 AM |
you may as well just mark it up and give it to joe, in my experience you will never stop it leaking from the outside, it will always eventually seep
through. the problem with welding up ali sumps is they need leak testing at least overnight with coloured dye, being cast you can get a bit of
porosity creep in that takes a while to show up. have modded tones of cast ali sumps and in my experience a good 40% need a second tickle with the
tig.
