locost 7 k
posted on 20/5/14 at 05:42 PM |
trail tech vapor dash
For sale is a never used trail tech vapor with the dash surrounding and everything bar the water temp sender to go with it, probably pick another up
quite cheap
The dash does everything you need it to do, speedo - water temp- revs - air temp - clock - odometer - turn signals - full/low beam lights
the speedo is a magnetic pickup
this dash can be used without a car battery or you can connect it to the car battery
Wanting to get £50 for it, cost more then double that from amazon
RWD Focus
posted on 20/5/14 at 07:26 PM |
Hi mate will you post?
locost 7 k
posted on 20/5/14 at 08:43 PM |
Yup, probably be £5
locost 7 k
posted on 20/5/14 at 08:58 PM |
Prov sold
