Hakuraa
posted on 23/3/15 at 09:52 PM |
New owner info request
Hi guys,
As a new owner of a Mac#1 Worx ZX10 I have a request for info please. Can anyone tell me the capacity of the fuel tank, advise on track day tyre
pressures, estimates on track day fuel consumption and wheel nut torque settings. Help gratefully received.
steve m
posted on 24/3/15 at 06:48 AM |
The only part I can offer any help with is tyre pressure's
I run 16 psi on all four, but other 7 users have varied from as low as 14 to the mid 20's
anything higher than mid 20;s will result in your car feeling like your driving on ball bearings
steve
CosKev3
posted on 24/3/15 at 08:26 AM |
Ref the fuel capacity, easiest way to work it out is go to the garage with it empty and tank it
Could well be a custom tank, if you know for sure its a Mac1 supplied tank give them a call, very friendly/helpful tbh.
PAUL FISHER
posted on 24/3/15 at 11:30 AM |
Trackday mpg will be around 12mpg, thats what I got with my Zx10r.
[Edited on 24/3/15 by PAUL FISHER]
Jon Ison
posted on 24/3/15 at 12:23 PM |
As much as that, I'm into single figures
Hakuraa
posted on 24/3/15 at 01:36 PM |
Thanks for the replies, lets me know how much fuel to take this weekend. Time to check the tyre pressures.
adithorp
posted on 24/3/15 at 02:10 PM |
Fuel tank could be anything from a 2 gallon sprint tank to a custom 10 gal'. Average common or garden kit car tank is around the 6 gal'
mark. You can either empty it and then brim it or do a few measurements (in cm's) and work out the volume. WxHxL/1000 = cap' in litres
Most BEC owners run between 16-20psi. Check them hot though asit can make a big difference on track.
Fuel usage on track could be anything from 8-20mpg. My R1 will do anything from up to 35 cruising, 25 spirited driving on road and down to 15-20 on
track.
Wheel nuts around 90nm.
http://jpsc.org.uk/forum/
Spud1985
posted on 6/4/15 at 08:18 PM |
if its the standard Mac#1 tank it will be approx. 32ltrs ....
I've just removed mine and happened to measure it to work out the current capacity compared to the replacement one I'm about to have
fabricated ............
TimC
posted on 6/4/15 at 08:33 PM |
Fuel @ 0.6litres/min if "on it."
Hakuraa
posted on 12/4/15 at 08:08 AM |
Thanks for all the replies.
Found that the fuel tank is circa 20 lts, went to a wet Blyton, never got the tyres to full temperature to check pressures, spun off at the bottom end
coming out of Bishops, found that my moving seat issue was not me being too heavy (although that is the case, must diet) but rivets stripped from the
floor/frame so retired to fix.
Cheers again,
Andy.
CosKev3
posted on 12/4/15 at 08:57 AM |
Pain your day was cut short.
Rivets holding seats to anything doesn't sound too good, which parts of seat were they holding together?
Hakuraa
posted on 12/4/15 at 04:34 PM |
Re read my post and it was not too clear, sorry.
Moved the seat forward, prior to the track day, to suit my leg length after purchase and found it pitched back and forth as I accelarated and braked,
but thought it was down to "body size" and the seat flexing, as the seats are built as standard for someone slimmer than I am. Only once
at Blyton during the afternoon did I happened to move the seat while looking at the floor and notice that the floor was pivoting downwards. Spoke to
Colin at Mac 1 and he said it is possible to remove the rivet heads on speed bumps etc if the driver is of a heavier weight than "normal",
which applies to the two previous owners too, hence my floor had come detached from the frame. On inspection all the rivets from the frame rail
behind the seat except the outside one had failed and 7 from the back rail forward on the transmission tunnel rail.
Have to say a bit disappointing but will be fixed tomorrow once work rota is completed today. Then it will be tested on the road and back to Blyton
hopefully on the 20th May, with the plan being to do the Nordschleife later in the year.
CosKev3
posted on 12/4/15 at 05:33 PM |
So your seats are not fitted to some steel bars welded to chassis?
CosKev3
posted on 12/4/15 at 05:36 PM |
You can see the flat steel bar across the floors where my seats bolt through in the pic above, mines a Mac1 toom
Hakuraa
posted on 13/4/15 at 04:40 PM |
No there are no other chassis rails or metal mounting bars apart from the one in front of the seat and the one behind the rear bulkhead
CosKev3
posted on 13/4/15 at 05:05 PM |
I would be getting some welded in, not a big job tbh.
I know some people say seats bolted through the alloy floor with large spreader washers are ok, but not a sniff I would have mine like that!
