Author: Subject: Concentric Clutch Slave Failure
mackei23b
posted on 9/9/15 at 08:50 PM Reply With Quote
Ok what am I doing wrong......
I'm trying to get my clutch working, the spec is:
Duratec 2l
Raceline bellhousing with V6 concentric slave cylinder
ST 150 flywheel
Clutch is a Helix heavy duty version, pinto drive plate with ST cover
I've fitted 2 new slave cylinders and both have leaked straight away......advice welcomed
Cheers Ian
Ben_Copeland
posted on 9/9/15 at 09:59 PM Reply With Quote
Sounds like your over extending them. Are they spaced so the bearing is close to the clutch?
Ben
Locost Map on Google Maps
Enter Your Details Here
mackei23b
posted on 10/9/15 at 06:35 AM Reply With Quote
Hi Ben
The first one that came out showed no sign of over extension, second one also had a clutch stop on the pedal to be extra safe, but will not rule this out
I've got clutch fluid leaking at both the front and back of the bellhousing....don't know if that is a useful clue.
Thanks Ian
Nitrogeno25
posted on 10/9/15 at 03:19 PM Reply With Quote
I've been using a cheap V6 slave from ebay for over 3 year (4000 miles) without problems (touch wood).
No spacer requiered with the V6 (mondeo) version.
Apart from leaking, is it working fine? Mine leaked a bit at first but tightening the nipple fix it.
Cheers.
mackei23b
posted on 15/9/15 at 03:34 PM Reply With Quote
Hi there
Yes it works, no slip and releasesOK just leaking......
Ian
