mcramsay
posted on 1/3/19 at 07:21 PM |
Vinyl wrap advice
I have been watching yianni the super car vinyl wrap bloke on tv, and figured I would at least have a go at trying it on my marlin as I don’t have the
money to paint at the moment!
I am completely prepared to find out it’s not as easy as it looks!!!!
My car is pretty much all fibreglass so I’m going to do a test wrap of a front wing just to see how it goes! The wing is currently in a beige gel
coat, do I need to prime this with standard primer and flat off before I can wrap? I’m not talking about to hide imperfections more if the vinyl will
adhere properly.
Also there are holes in the wing for mounting and indicators, will the vinyl stick to the inner (non gel coat) OD of the hole or again do I have to
prime / seal this surface?
Any tips would be great!
The Knobs
posted on 1/3/19 at 08:17 PM |
I was just thinking of doing bits of my Striker with vinyl, watching this thread with interest lol
Slimy38
posted on 1/3/19 at 09:37 PM |
Vinyl is remarkably sticky, it'll stay put on most surfaces. Gel coat will be no problem. I'd just suggest a degreaser with IPA or
similar. Note that it will pick up any slight imperfection in the panel, that was my biggest regret when doing my bike. Even the decals that I left on
the panels actually showed through the vinyl, remarkably cleanly.
I would recommend starting with only a single curve panel though, if your wings are how I think they are you will have trouble with the leading edge
as it makes a 'dome'. I'd actually suggest a bonnet or similar flat panel, you'll soon find the size of a panel isn't as
critical as how many curves it has.
Oh, and be sure you want to do it, it's amazing how the stuff doesn't actually come off like it does on Youtube!!
mcramsay
posted on 1/3/19 at 09:53 PM |
Thanks for the info! I wanted to try on the wing as if I can do that with good results then I’m confident I can do the easier panels, I’m going to
take my time put in the prep and not get fustrated.
I don’t want to wrap all the easy panels only to find I can’t do the difficult ones!
I expect by the end of tomorrow I will be looking at painting the thing!
The Knobs
posted on 1/3/19 at 10:04 PM |
Which vinyl is the best for diy?
40inches
posted on 1/3/19 at 11:31 PM |
3M 1080 is designed for car bodies ![](/images//smilies/wink.gif)
CosKev3
posted on 2/3/19 at 09:28 AM |
As Dave says,3M 1080
There is a big difference between cheap vinyl and premium brands
Big T
posted on 6/4/19 at 10:11 PM |
It’s suprisingly difficult in practice. The amount of times I’ve watched a video and then given it a go. Like plastering a ceiling. Never again.
Some vinyl is better to work with than others. I’ve used multiple brands and all are supposedly automotive intended. Best I’ve used was a “Hexis”
branded item. But it was expensive.
I imagine the most complicated part of a Seven style vehicle would be the rear arches and nose cone.
