Jumpy Guy
posted on 24/6/05 at 12:56 PM |
fuel fillers - do they have to lock?
we use fuel fillers at work that dont have alock and key
however, they need a special tool to open them, similar to locking wheel nut key..
so a passer by couldnt open it..
is this enough?
posted on 24/6/05 at 01:17 PM |
Would have thought so - let me check the manual...
Nope they don't have to lock - as long as you have one on, it is secure and dont leak fuel you should be alright. Though for peace of mind
I'd want a lockable one - similar to the one you describe.
HTH
[Edited on 24-6-05 by Hellfire]
DaveFJ
posted on 24/6/05 at 02:39 PM |
Errr maybe I'm missing the point here...
Fuel caps need to locking in some way. either directly or behind a locking flap as in most modern cars. This is a basic MOT fail so must be an SVA
fail ?
Dave
Berwyn
posted on 24/6/05 at 03:37 PM |
No lock on mine and went through the SVA with no problem. Mine was from Europaspares, not sure this link will work but here goes...
https://secure.visav.co.uk/avshop/products.asp?sword=fuel%20cap&page=&showitem=1762
24 hours in a day, 24 beers in a case. Coincidence? I think not
posted on 24/6/05 at 04:45 PM |
Image deleted by owner
First column is pass criteria
Second column is fail criteria.
posted on 24/6/05 at 05:48 PM |
Fuel caps do not need to lock for an SVA or for MOT test , they need to be secure and seal properly thats all.
flak monkey
posted on 24/6/05 at 05:52 PM |
If that is true....how come several people have failed for not having a locking filler cap? Some have even failed due to having a non locking cap
inside a locking boot IIRC.
Sera
http://www.motosera.com
tks
posted on 24/6/05 at 07:49 PM |
mhh
where is the flap rule then??
that you cant put leaded hose in unleaded car..
?? the reduction??
Tks
posted on 24/6/05 at 09:43 PM |
Because Mr SVA hasn't read his book properly I guess it could be interpreted in many ways and who wants to upset him afterall?
@tks I think the reduction is to accomodate 22mm fuel nozzle (spout) (whatever it is in Spanish)
[Edited on 25-6-05 by Hellfire]
tks
posted on 27/6/05 at 04:50 PM |
yeah indeed
but i ask where states the book that rule??
Tks
