Author: Subject: Wireless testing software
mookaloid
posted on 12/7/06 at 10:14 AM Reply With Quote
Any one know of any free software which will look at wireless networks?
I can see about 6 other networks from my office and I just want to know which channels they are using so that I can avoid them.
Not interested in hacking etc.
Mark
davida
posted on 12/7/06 at 10:27 AM Reply With Quote
Hi Mark,
It's usually possible to get Windows or your existing wireless adapter utility to report the available networks.
There are lots of tools available for digging a little (or a lot...) deeper but I've found this tool to be pretty simple:
http://www.passmark.com/products/wirelessmonitor.htm
Regards
Dave
[Edited on 12/7/06 by davida]
mookaloid
posted on 12/7/06 at 10:45 AM Reply With Quote
Thanks Dave, just the job!
Mark
DaveFJ
posted on 12/7/06 at 10:49 AM Reply With Quote
Although there are channels available, changing doesn't really help much. the channels are so close together and the tolerances that the cheap routers work to so wide that you get interference across all the channels..
Basically anywhere you can detect more than 4 networks (possibly less) you can pretty much be assured that your connection will be crap. (que 10 people saying otherwise). this is based on recently having to carry out over 100 home installations for our employees using a variety of kit.
Dave
mookaloid
posted on 12/7/06 at 11:07 AM Reply With Quote
Well I found 4 on channel 11 including me and 2 on channel 6 so I've moved to channel 2.
In fairness I wasn't experiencing much in the way of problems, I just wanted to be a bit proactive in keeping my network healthy.
Mark
jamesbond007ltk
posted on 12/7/06 at 12:32 PM Reply With Quote
There is a very useful piece of software called netstumbler that will tell you anything you need about networks in your area.
need4speed
posted on 12/7/06 at 04:53 PM Reply With Quote
You should only use channels 1,6 & 11 other wise you interfere with the others as each channel covers 5 bands, so rather than use channel 2 use 1 and if you can't find a free one your still better using the same as someone else as 802.11 is designed to cope with that but it won't cope with interference.
Not as it's part of my day job or anything!! Airmagnet it best to use but expensive to buy.
Dave
