liamb
| posted on 14/1/08 at 09:40 PM |
Stupid brake questions
Hi all,
My build is progressing ok and I have just got around to fitting the rear brakes but I really know nothing about how they are supposed to fit together
so I just had a bash at it to see what makes sense.
I have attached a photo of the first one (rear passenger side) and was wondering whether someone with more experience could cast an eye on it and
check I have the right idea.
Also, is it right that the pads are mounted using the long pins that run along the top of the calliper? There appears to be no mechanism for pulling
the pads off of the disk when not braking, is this correct (sorry to ask a dumb question).
Finally, also trial fitted a wheel but the Team Dynamic wheel nuts do not appear to fit the threads on the sierra hubs. They almost do but not quite.
IS this just a case of using a little more force?
Liam
matt.c
| posted on 14/1/08 at 09:41 PM |
OMG! My screen has just blown up!!!
RESIZE PLEASE
liamb
| posted on 14/1/08 at 09:45 PM |
Sorry, did not realise it would be that back (and low quality).
Cant seem to edit original so here is a more sensible size photo.
bigrich
| posted on 14/1/08 at 09:50 PM |
is this any clearer Liam
bigrich
| posted on 14/1/08 at 09:56 PM |
and this is when i was measuring for the spacers i needed
liamb
Cheers Rich,
Looks like I have done it ok. Is it right that there is nothing to pull the pads off of the disk or do the pads stay in contact?
Did you have any problems with the wheel nuts not fitting well when you built?
As every, really appreciate the help.
Liam
bigrich
| posted on 14/1/08 at 10:01 PM |
its the action of the pistons retracting that allows the pads to move away from the discs giveing clearence.All disc brakes are like this.
As for the wheel nuts no problems here,you havent painted the studs have you when you painted the hubs as this would make the studs/nuts very tight to
do up
Rich
[Edited on 14/1/08 by bigrich]
liamb
| posted on 14/1/08 at 10:05 PM |
Yes, paint on threads, I will clean them up and see how I go.
Liam
| posted on 15/1/08 at 11:45 AM |
One tip is to make 100% sure the brake calipers are as parallel the swept surface disk (in both axis) as possible, even a few a fraction of a mm out
will cause a spongey pedal.
Use feel guages, to check this as best you can.
