Author: Subject: Side and back panel joint - pics?
Slater
posted on 13/2/08 at 01:18 PM Reply With Quote
Hi, does anyone have any good detailed pics of where the MAC#1 fibreglass side panel and back panel join? i.e. the area below the roll bar mounts, above the top of rear wheel arch.
I am trimming both my panels to fit and want to see how everybody else has done it..... obviously I don't want to make a mistake!
Keith.
[Edited on 13/2/08 by Slater]
DarrenW
posted on 13/2/08 at 03:47 PM Reply With Quote
Best joins i have ever seen were on an early MNR where they filled the joint with gel coat and also on Hellfire 2. They made an ali trim to cover the join - and a very smart trim it was too.
Howlor
posted on 13/2/08 at 03:58 PM Reply With Quote
I don't think I have a close up pic of mine on the early MNR but I glassed up the joint from behind then just filled it with gelcoat. Rubbed it all down until polished to match the rest of the car and although visable were not obvious.
bigrich
posted on 13/2/08 at 08:28 PM Reply With Quote
just checked my pictures and don't have a single shot of that joint.
If you dry fit the sides and do a vertical cut halfway across the roll bar plate/shocker centreline
then the rear panel needs a 25mm square taking from the lowerreturn at its front point to allow it to fit onto the rear chassis rail,then the overlong top edges will over lap the sidesand once they
are level to each other can be marked and cut vertically again to give a good joint
Then the area around the shocker/spring can be trimmed back for clearence but don't go too high or the arch wont cover the cutout,
I found a joiners sliding square great for marking the straight cuts and a fibreglass blade in the jigsaw to do the cutting
Dont forget to trim back the overlap on the angles that go up to the roll bar plates from the floor level
Will take some piccys fo my joints and post them later for you
Rich
Slater
posted on 13/2/08 at 09:09 PM Reply With Quote
Thanks Rich, I think I've got the idea, but any pics will be very helpful. I need to see how you've cut the fibreglass around the rollbar mounts.
Keith.
neilj37
posted on 13/2/08 at 09:27 PM Reply With Quote
Hows the build going? You going to be able to join us for a blat this summer?
bigrich
posted on 13/2/08 at 09:34 PM Reply With Quote
Keith
fit the sides and rear panel then when fixed in place, position the rollbar over the panels and locate with the bolts then mark around the rollbar, remove it and trim back the panels with a dremmel type tool and sanding drum to your marked line then refit the rollbar and bolt down
Rich
[Edited on 13/2/08 by bigrich]
Slater
posted on 13/2/08 at 09:38 PM Reply With Quote
Neil. The build is going great, I'm realy enjoying it. Engine/Gearbox is ready to go in [you don't happen to have an engine hoist I can borrow?] I've rolled the chassis outside a few months ago, but it's back on the stands now, still got to tackle the wiring and lots more. I reckon summer 09 for getting it finished. I'm in no rush, it's the building part that I like. Come over and have a look if you're interested.
Keith.
bigrich
posted on 13/2/08 at 09:49 PM Reply With Quote
just nipped into the garage for a couple of piccys
side/rear joint Rescued attachment side panel cut.jpg
bigrich
posted on 13/2/08 at 09:50 PM Reply With Quote
Slater
posted on 13/2/08 at 09:55 PM Reply With Quote
Sterling Effort! Thanks Rich.
neilj37
posted on 14/2/08 at 05:59 PM Reply With Quote
No sorry I don't have a hoist I have always hired one when I needed it
ash_hammond
posted on 15/2/08 at 12:15 AM Reply With Quote
Here is my 2'peneth......
.: www.mac1motorsports.co.uk | www.m1moc.com :.
ash_hammond
posted on 15/2/08 at 12:18 AM Reply With Quote
Better resized pictures
ash_hammond
Another
ash_hammond
posted on 15/2/08 at 12:19 AM Reply With Quote
Another 3
ash_hammond
posted on 15/2/08 at 12:24 AM Reply With Quote
Hi Slater
I have an engine hoist kicking around my garage if you would like to borrow it. There is also a kit car in there with fitted pannels if you would like to take a 3D look.
Ps i am in Sheffield 5 mins away from MAC#1, if thats local. to you.... My U2U does not work so best dropping me a line...
07815952516
- Ash
ash_hammond
posted on 15/2/08 at 12:26 AM Reply With Quote
Just seen your location.... perhaps its not so local after all.... Worth a shot.
[Edited on 15/2/08 by ash_hammond]
omega 24 v6
posted on 15/2/08 at 06:10 PM Reply With Quote
Slater you have U2U
