mistergrumpy
posted on 21/5/08 at 10:55 AM |
Rear Light Markings
I've been looking at my rear lights and reading the SVA manual I'm now a bit confused. It seems all my lights are same with E1 1544
markings and AR markings but 5 have SAE-U-DOT markings and 1 says SAE R 05 DOT. I don't know which is what. The book says rear indicators to
have 2a,2b or 12 markings stop lamps to have s1,s2 or s3 markings. Also the fog has to have B or F and have a minimum of 150 candelas. Is this
dictated by the reflector? Cheers in advance
RazMan
posted on 21/5/08 at 01:34 PM |
I'm not sure about the numbers, but Mr SVA will be happy with ANY lights as long as they are deemed 'of suitable brightness'. E
markings are just a confirmation that they were manufactured to a certain standard - not that they will pass SVA.
Raz
HAL 1
posted on 21/5/08 at 02:20 PM |
Razmans right, they just have to do the job,
the big square foglight looked odd on my car, but somehow managed to change itself into one that looked ok.
mistergrumpy
posted on 21/5/08 at 03:15 PM |
Excellent. Thought I'd dropped one there. What about the rear fog light then? Is it the reflector that makes the difference in its brightness?
I'm guessing I can't just use one of my spare lights with a red bulb in to keep things all looking the same.
RazMan
posted on 21/5/08 at 03:56 PM |
Technically you can use anything you like but if the tester thinks it looks a bit iffy he might THEN look at marking to see if it complies with any
standard spec.
For example my lights are all LEDs and the fog lights are actually day time brake lights as well. However when it comes to checking function they look
ok so pass without question - tbh I think the multi function thing just confuses the tester
Raz
mistergrumpy
posted on 21/5/08 at 04:50 PM |
Well I was looking at this but it doesn't look
marked up or any different to the same brake lights and indicators and presumably no brighter so I couldn't understand why it was being sold as
a fog light.
adithorp
posted on 21/5/08 at 06:09 PM |
Stricktly speaking brake lights won't do as fog lights. Pretty sure its specifficly mentioned in the manual. The reflectors are different and
give a narrower more intense beam. Having said that it's down to interpretation but if Mr SVA dosen't like it you'd have to prove it
wasn't a brake light. I decided not to risk it.
adrian
mistergrumpy
posted on 22/5/08 at 08:28 AM |
Yeah you're right Adrian. Fog lights need a minimum of 150 candela whilst brake lights need a maximum of around 90 candela I think. I think I
may have to get a chap square one then change it after SVA.
RazMan
posted on 22/5/08 at 08:35 AM |
The difference in candle power is quite suprising considering that both light units use the same power bulb (21W)
I guess the secret is in the reflector
Raz
mistergrumpy
posted on 22/5/08 at 08:40 AM |
Aye that's what I was thinking too. What about if I shove an apple pie foil tin in there? You reckon I'll get away with it
RazMan
posted on 22/5/08 at 10:40 AM |
Hmmm maybe an M&S one would do it or maybe a Mr Kipling?
Raz
