ricklawn
posted on 23/5/08 at 07:26 PM |
Bike Fuel pump
Hi
I have just spent the last few hours fitting a GSXR750 fuel pump in place of the facet pump that was fitted. Could anyone tell me if it looks ok
and in the right place. The reason i ask is that the pump brackets are rubber mounted and although i have used rubber bobbins ther seems to be a bit
of play.
Rick
![](/galpreviews/gsxr fuel pump 4.JPG) ![Description](/gallery/gsxr fuel pump 4.JPG) Description
[img][/img]
posted on 23/5/08 at 08:48 PM |
Looks good to me!! I think I've got the same pump in my BEC
A bit of wobble isn't a problem. In fact it will probably be a good thing. If you attach it too rigidly it'll vibrate and you might get
fuel foaming....
ANDYSHORT
posted on 23/5/08 at 09:00 PM |
why the change did u have problems with the facet pump -ie over fueling
ricklawn
posted on 23/5/08 at 09:37 PM |
i am changing because i am also fitting gsxr750 carbs in place of the twin webbers. should get carbs back from Boggs with nice new manifold in the
next week or so. Bike pump is better as it doesn't over fuel like facet. hopefuly.
tegwin
posted on 23/5/08 at 10:39 PM |
I have that exact pump as well...
Does it have to be mounted vertically like that?...
And which is the input and which is the output?
www.verticalhorizonsmedia.tv
ricklawn
posted on 24/5/08 at 08:25 AM |
Morning Tegwin.
too late to reply last night. i only mounted it that way because it fit the space better and the fuel pipes that came with it were bent in the
directions i needed. but i dont think it makes a difference. i have arrowed the directions of flow. hope it helps
Rick
[img][/img]
tegwin
posted on 24/5/08 at 04:36 PM |
Chears for that....really usefull
