TimC
posted on 24/5/08 at 02:34 PM |
Squeezing tight boots over steering rack.
Ugh - Afternoon All.
The boots that I have fior my rack are quite stretchy but a complete nightmare to get on;
Does anyone have any tips? I've had to walk away from the job for now - infuriating!
Jon Ison
posted on 24/5/08 at 02:46 PM |
I like girls in tight boots..........![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
when I've had that problem I find a nice log thin screwdriver helps, bit like putting a tyre on ? Put one side on a slide the driver around
feeding the rest on, not as easy as it reads but @,m sure you'll get there.
worX
posted on 24/5/08 at 02:52 PM |
Cut your nails, put on a decent pair of gloves ( ) and just sacrifice those fingers!!!
They will go on!
blakep82
posted on 24/5/08 at 02:55 PM |
i eventually managed by a combination of grease/oil, long screwdriver as described above, and also the thick end of some tie wraps, so that they poke
outwards inside the rubber, have someone help by pulling on them gently, and the part poking out should grip the inside of the rubber, and should pull
over the rack. thats what i did, with some sucess. although i did it on my own with only 3 tie wraps. a helper and about 6-8 tie wraps should be a lot
easier
________________________
blakep82
posted on 24/5/08 at 02:56 PM |
YES!
steve's right, cut your nails. i didn't (i hate the way they feel when they've just been cut... i'm a wuss, and i have long
finger nails lol) i bent one of my nails right back... wasn't amused.
cryoman1965
posted on 24/5/08 at 03:19 PM |
Put them in some boiling water first to make them more plyable.
N
posted on 24/5/08 at 03:29 PM |
WD40 the inside of the rim and a flat driver to shoehorn them on. If it's an Escort rack one end is bigger than the other isn't it?
RazMan
posted on 24/5/08 at 03:50 PM |
Warming the boot up in hot water certainly helps, but you have to work quickly before it cools. Silicone grease works well too.
Raz
grazzledazzle
posted on 24/5/08 at 04:31 PM |
Hot water and baby oil.... ![](/images//smilies/bigsmile.gif)
eznfrank
Did you get a fitting cone with them?? If so, throw it in the bin.
ricklawn
posted on 24/5/08 at 04:38 PM |
Is that fingernails or rubber boot![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
blakep82
posted on 24/5/08 at 04:55 PM |
yeah, i couldn't understand how they worked...
cryoman1965
posted on 24/5/08 at 07:40 PM |
I didnt know this was a sex advice site!!!
N
