New Topic New Reply
Author: Subject: Zetec cams
ricklawn
posted on 28/6/08 at 10:43 AM Reply With Quote
Zetec cams
morning all
I have a 1.8 zetec blacktop, and have just bought some 2l cams and lifters. i thought the blacktop lifters were hydraulic, as the ones i bought (said to be out of blacktop) seem to be solid with shims on top.
Can i still put the new cams in with my old lifters??
[img][/img]
Rick
theconrodkid
posted on 28/6/08 at 10:47 AM Reply With Quote
blacktop are solid and no you cant use hydraulic ones,have fun shimming them up
who cares who wins
pass the pork pies
Dusty
posted on 28/6/08 at 10:51 AM Reply With Quote
Silvertop - hydraulic, Blacktop - solid/shimmed. If you have recieved solid lifters with the new cams that is right. Your 1.8 should also have solid lifters.
ricklawn
posted on 28/6/08 at 12:20 PM Reply With Quote
Hi
Got very confused as i was looking at www.zetec-cat.co.uk for reference, and my engine been a mark one, it says hydraulic lifters.
Mole
posted on 28/6/08 at 02:58 PM Reply With Quote
Cant be a mark one if its a black top
ricklawn
posted on 28/6/08 at 03:56 PM Reply With Quote
according to zetec- cat ref page my engine is a phase 1??
theconrodkid
posted on 28/6/08 at 04:07 PM Reply With Quote
is the sump 1 piece ally or ally with a steel bottom half?,1 piece is silvertop/phase 1+2,got any pics?
who cares who wins
pass the pork pies
Werner Van Loock
posted on 28/6/08 at 05:56 PM Reply With Quote
As above, also the silvertop has the waterpump pulley just above the crank pulley while on the blacktop it's offset to exhaust side.
Also it doesn't mean if the rockercover is black that it is a blacktop, could be painted afterwards.
http://www.clubstylus.be
ricklawn
posted on 28/6/08 at 06:01 PM Reply With Quote
its got a aliminium cam cover with DOHC on it
Rick
Mole
posted on 28/6/08 at 07:13 PM Reply With Quote
Then its a phase one, i.e silvertop. (same as mine). The cams you have bought are for the later phase three (blacktop) engine.
[Edited on 28/6/08 by Mole]
bob
posted on 28/6/08 at 07:26 PM Reply With Quote
Yup sounds like phase 1 if DOHC on cam cover, probably the cam cover has had a paint job.
Easy way to decifer is by engine numbers, phase 1 silver top 1800 will have 3 ltters stamped on the block near the crank position sensor as well as engine numbers.
phase 1 1800 should read letter R to denote 1800 then either letter D for 105 cams or letter K for 115 cams or letter Q for 130 cams, 3rd letter is random or denotes power or what car.
Hope this helps
[Edited on 28/6/08 by bob]
New Topic New Reply
