Author: Subject: cortina brake upgrade
madteg
posted on 30/8/08 at 10:40 PM Reply With Quote
What is an easy upgrade for cortina front brakes as i did my first trackday today and had brakefade, its not nice is it.
[Edited on 30/8/08 by madteg]
gregf27
posted on 30/8/08 at 10:53 PM Reply With Quote
first thing to do is replace your pads.
mintex 1144 or ferodo DS2500's will make a huge difference, try that before wanting to swap calipers and the like
Greg
posted on 31/8/08 at 12:59 PM Reply With Quote
Capri 2.8 vented discs and fit spacers to widen the calipers.
Also check your brake pedal isn't sticking slightly -- make sure the pedal has a return spring and the fluid resevoir isn't over filleded.
tomblyth
posted on 31/8/08 at 04:21 PM Reply With Quote
agree you should sort out pads and fluid first then have a look here!
http://www.hispecbrake.co.uk
[Edited on 31/8/08 by tomblyth]
