Author: Subject: Reverse Gear / Bike Engine
grusks2
posted on 31/10/08 at 09:05 PM Reply With Quote
As the new Sva test is on the way in april ( im hoping to be finished before then as long as work picks up) what on offer in the way of reverse gears for the Worx's.
[Edited on 31/10/08 by grusks2]
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
posted on 31/10/08 at 09:20 PM Reply With Quote
1) Mechanical inline reverse box
2) Electric reverse "home-brew"
I'm not aware of any off-the-shelf electric reverse mechs. I think STM sold one but it was fairly home-brew IIRC... (ie in constant development)....
posted on 31/10/08 at 09:39 PM Reply With Quote
Hmm, my gearbox came with reverse. A Ford type 9, and the Toyota W58 going in has reverse as well.
Why not use a box that has reverse??
stuart_g
posted on 31/10/08 at 10:21 PM Reply With Quote
How boring are these constant remarks, yawn, yawn.
If you have nothing constructive to offer in a post regarding BEC's why bother posting. Your constant anti BEC is getting very boring. You don't see BEC owners heckling every post you put up so why do it to posts put up by BEC owners?
AB Performance does a mechanical one supposed to be good quality or there is this one
[Edited on 31/10/08 by stuart_g]
posted on 31/10/08 at 10:31 PM Reply With Quote
Because then I'd always be jealous of those with a BEC and would find it necessary to mercilously mock them
grusks2
posted on 31/10/08 at 10:47 PM Reply With Quote
[quote
Thats better a proper answer , Have you a web site for AB performance.
I fancy the electric route to be honest, all ready got my propshaft, so dont really want another 2 made up for the reverse box route.
This post was meant for the owners of mac#1 and what have they done or going to do reverse gear wise.
tomgregory2000
posted on 31/10/08 at 10:56 PM Reply With Quote
cut 2 holes in the floor and tell them that u want to do it flinstone style and use your feet, they cant argue with that
YQUSTA
posted on 31/10/08 at 10:59 PM Reply With Quote
http://www.abperformance.co.uk/default.htm
Also these guys
http://www.lynxae.co.uk/Products-Bikesports.htm
spoke to them a while back very helpfull guys
YQUSTA
[Edited on 31/10/08 by YQUSTA]
Triton
posted on 31/10/08 at 11:16 PM Reply With Quote
Take one bike starter motor and have gear cut in some kind of plastic to match the pitch on starter...mount gear on diff like a space then rig up starter to either slide into place or have it lowering...
plastic gear will shear teeth if something goes pear shaped and accidently chunks into reverse. go as big as you can in the given space for the gear and will throw you backwards quicker than you imagined a wee bike starter should!
those reverse box things are heavy and if memory serves me right turn into "oil pumps" and chuck oil everywhere
www.tritonraceseats.com
www.hairyhedgehog.com
Bigheppy
posted on 31/10/08 at 11:41 PM Reply With Quote
This is a valid comment, has anyone investigated using a car gearbox on a bike engine. I know many will comment on the weight and complexity of a car gearbox but it could be an answer to many peoples prayers.
AdrianH
posted on 1/11/08 at 12:00 AM Reply With Quote
But generally the bike engine has the gearbox built in.
That helps with the power to weight ratio.
To take a drive without the gearbox would mean a lot of mods to crankcase etc.
The last time I saw one without, was on a Triumph pre-unit twin, then there is the American series of twin cylinder lumps as used on American Chopper.
On Saying all that what does a VW air cooled engine use, that has a separate box
Adrian
[Edited on 1-11-08 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
trialsman
posted on 1/11/08 at 01:43 AM Reply With Quote
I think he means using a car gear box in ADDITION to the bike gear box. It would be in line with the prop shaft. Take a gear small box (like a Suzuki Samurai) cut the bell housing off. Attach the bike output to the gear box input. Gut the gears out of it leaving only the 1:1 ratio forward gear and the reverse gear. I don't know if it is possible or not. Seems feasible. Russ
[Edited on 1/11/08 by trialsman]
zilspeed
posted on 1/11/08 at 09:10 AM Reply With Quote
Me - I have considered it.
I think with the right box it's very much the locost way. Light gearbox is the answer.
More updates very soon.
irvined
posted on 1/11/08 at 12:33 PM Reply With Quote
There was a guy a while ago with a green busa powered seven and a car gearbox. I can't remember the configuration, but there were some videos posted.
http://irvined.blogspot.com
posted on 1/11/08 at 06:35 PM Reply With Quote
Well, I get constantly bombarded with comments like 'should have put a bike engine in it' but that wasn't the point of my post. It was abit tongue in cheek I admit.
Reverse boxes for bike engines are ridiculously expensive but car gearboxes have a reverse gear and shift. Isn't about time some one found a way of using a car gearbox as a secondary gear up or down device with reverse?
This is a forum, and forums are about discussion.
TPG
posted on 1/11/08 at 06:36 PM Reply With Quote
A good point, A friend of mine built a JZR a quite few years ago with a Hardly Dangerous engine in it. He mated that upto a Ford gearbox. Now what bike engine is North-South I don't know.The V-twin looked bang on in a very early Morgan replica.How you go on for a locost style.....
..Which was nice..
zilspeed
posted on 2/11/08 at 04:02 PM Reply With Quote
I have done just that.
Yesterday I pciked up an adapter from a member of this forum who has a waterjet machine.
Centre spline are the same as a ford small clutch, four bolt holes are the same as Ford propshaft PCD.
Can you see where this is going ?
Pics when I find my pheqin' camera.
