mr_pr
posted on 2/11/08 at 03:54 PM |
Drive Shafts....
I have this
and I need to undo this nut I assume to get the sierra hubs and bearing carriers off? (The car is using a freelander diff)
The nut is FT. So before I give myself a hernia trying to remove it, it does need to come off right? Any tips?!
Andy W
posted on 2/11/08 at 03:59 PM |
One side is left hand thread
Richard Quinn
posted on 2/11/08 at 04:07 PM |
I suppose the whole shaft may fit through the hole in your upright allow the bearing carrier to bolt on the outside. However, if you want to
check/change bearings, it would be sensible to do it at this stage. They are VFT and the nearside (if you can tell off the car) is left hand thread.
eznfrank
posted on 2/11/08 at 04:24 PM |
Not easy with it off the car. Work out which thread is which one, maybe a bit of lube and big bar and bring on the hernia!!
Bigheppy
posted on 2/11/08 at 04:59 PM |
Once youve worked out which thread youve got, get a long piece heavy weight flat bar or angle drill a hole in one end and bolt it onto the drive
flange. Using a good quality socket with a long extension undo the nut allowing the bar to rest against the next stud.
mr_pr
posted on 2/11/08 at 05:20 PM |
Ok, so it is just FT then. Oh well. It does need to come off then...
I'll get 999 on speed dial for tomorrow...
craigsimon77
posted on 2/11/08 at 09:48 PM |
I just did this to my bmw e30 drive shafts, off car (makes it pretty tough) I put the brake rotor back on which was buggered anyway and clamped that
down in the vice. I had a 2m piece of pipe slid over my breaker bar and it still was tough!!!!!
DarrenW
posted on 3/11/08 at 12:33 PM |
Another option is to try friendly garage if you cant get them undone at home. Some may have a heavy duty pro impact wrench. You will still need long
pry bar to lock between the studs though.
Not sure but you may be able to use a nut splitter if all else fails.
mr_pr
posted on 3/11/08 at 06:21 PM |
Well I managed to get the left hand threaded one off by myself but admitted defeat on the RHT.
A local Land Rover mechanic helped me out though...
So now I have it like this.
Do I need to remove the Hub end to fit to the Mac#1 supplied half shaft? If so, how do I get it off?
Ed
bigrich
posted on 3/11/08 at 10:27 PM |
you have u2u.
piccy to help explain
mr_pr
posted on 3/11/08 at 10:37 PM |
Thanks for the u2u.
I'll have a crack tomorrow.
Thanks again Rich.
mr_pr
posted on 4/11/08 at 09:10 AM |
Cheers Rich, they came apart nicely.
Just need to clean up the bits and reassemble now!
bigrich
posted on 4/11/08 at 09:48 PM |
Ed
just be sure you fit the driveshaft end with the L/H thread to the shorter new shaft so it ends up on the N/S of the car(pass side)
