Hi all!
I'm trying to figure out the simplest and most cost-effective way of building a mid engined car. Are there any problems to be expected when
building a chassis in three different segments, then bolting or welding them together afterwards?
I was thinking about modifying book/McSorley plans - build the cockpit area, skip the engine compartment, build the front suspension bit and mount it
to the frame. Then fabricate a subframe for the rear to fit the engine and transmission from a FWD car.
Are there any serious problems to be expected when constructing a vehicle this way?
As long as the joints are solid and well located, there should be no problem. Does add weight tho'.
I would take the front subframe and engine from a mondeo ST and build from that.
Well, it's going to be for fun and on a tight budget.. No big HP figures here.. Donor vehicle would probably be a Fiat or maybe an Alfa if I can get parts cheaply enough..
ok then....
I would take the front subframe and engine from an Alfa and build from that.
There was a chap in PPC that did something similar - think he had a longitudinal Renault engine! I used Locost front suspension but then my own stuff
after that - used Locost dimensions for the cockpit though.
You could always use a Rover Metro front subframe. Oh hang on, that'd make it an MGF then....! (or a GTM)
Check out Midlana
Originally posted by kb58
Check out Midlana
Originally posted by JC
There was a chap in PPC that did something similar - think he had a longitudinal Renault engine! I used Locost front suspension but then my own stuff after that - used Locost dimensions for the cockpit though.
The easiest way to make a mid engined locost is to put a bike engine in the passanger seat, and minimilise the old engine bay to just support the front wheels. You would admittedly only have one seat though.
Originally posted by akumabito
Ooohhh, that looks pretty much exactly like what I had in mind.. Nice project! IS it also more-or-less based on the locost, or did you design the entire chassis from scratch?
