Hello,
my friend looking for install a reverse gear in his sylva powered by ZX-12R engine.
i have checked his chassis but there is very little space.
Less then 6 inch around rear diff flange (<3" radius).
while near front output flange, the space is less... about <1 inch between flange and water pump or chassis..
some one has installed reverse gear on this car?
in your opinion it's possible to do?
thanks
Hi
If you don't have the room for an electric one.
The only other option is a reversing box & 2 propshafts.
Not cheap but better than electric (only my opinion)
Good luck
René
I along with many others have used a VAG starter motor and a spur gear fitted to the diff flange.
Most use Sierra running gear, but it would be possible to adapt to other types. I should say that this system will not
get you very far reversing up a slope. Some info in my photo archive.
thankyou for your fast reply!
@ renetom
my friend have a reverse gear box from his old westfield...
if the electric version would be impossible to achieve we will use it.
@ 40inches
thanks for input, how much is diameter of bigger cogwheel in this photo?
[Edited on 20/11/12 by HPDxxx]
@ renetom
@ 40inches
Originally posted by 40inches
5.5 inches I had to form a slight bulge in the side panel for the motor bracket.
U2U sent
omg
thats sound perfect! where come from your biggest gear?
