Sierra steering UJ
gaz05 - 9/6/14 at 09:30 PM
Took my top steering UJ to bits today due to some wear. Thought it was a standard 15mm size which should be easy to obtain but the holes are 14.8mm. Ford say they can't get them. Anyone any idea of the equivalent sizes or a part number.
It's the joint that is nearest the triangular end of the column. Thought I'd try here before I splash out on a 15mm reamer that I'll never use again.
Gemini - 10/6/14 at 11:16 AM
have you tried GBS, i got one from them previously but not sure of size. was standard sieera bits
gaz05 - 10/6/14 at 04:37 PM
Tried everywhere. Went to CPS drivelink who did my prop and they've reamed it and supplied me a joint for £20.
