Hi All - see below for Thatcham Cat 1 alarm, various engine parts, lights etc etc
Lights £8
Pedals £4
Fuel Pump from Caterham 1.6 £5
Focus ST170 Pedal box with clutch master cylinder £10
20t Mild Steel trigger wheel - centre bore approx 40mm, OD 65mm - good for speedo trigger £5
1.8 CVH Engine - condition unknown! everything you can see in the pic - fuel pump, carb, water rail, head + block etc £50
Cone breather / carb filter - 60mm inlet I think, 80mm total height £3
Brake fluid reservoir (ex BMW e39) - 3 outlets with float switch for low brake fluid warning £8
Twin H4 Hi-Lo 4500k HID kit - was on my VFR and very very bright - 1 new bulb needed £15
MGF Heater Box with fan, wiring and matrix - could be modified to suit a 7 if you're keen! £10
Sierra Bolt-On Shaft rear wheel bearing kit - think one side only £5
Cortina Solid Discs - Suit westfield and so on - New - surface rust from storage £8 pair
New TOAD Ai 606 Thatcham Cat 1 Alarm and Immobiliser with 2 fobs and instruction - fitted briefly to check operation - £45
Stainless braided brake hoses M10 x 1 - 380mm overall - ask me to check if interested £15 pair
Lower part of ST170 steering column £10
2002 ST170 Front Uprights £15 pair
2002 ST170 Battery Box and Strap £5
Sierra 1.8CVH Alternator £15
Zetec 1.8 Flywheel £30
Sierra Pressure Plate £10
Sierra Sandwich plate CVH £15
I believe these are referred to as "Dinky Winkaz" £5
Ford Oil Cooler Sandwich plate - bolt between oil filter and block and T the tails into the cooling system for instant oil cooling £15
Leather Gear Surround Mk2 MGF £5
Pair MGF Electric Mirrors - suit westfield with the right loom £15
MGF 1.8 VVC Flywheel and pressure plate £15
MGF header tank and cap £8
MGF Airbox and filter £10
MGF Wiper mechanism and motor £10
Ive also forgotten to list a starter motor and one or two other bits you can see in the pictures! U2U if you see anything you need
Have you got the drive shafts off the ST??
Hi Steve,
No fraid not
Thatcham Alarm sold pending payment
Hi,
Are the heater and wiper mechanism still available ?
Thanks,
Mauro
Can I have the Dinky waz
Second dibs on the wiper please
The original post is 8 months old...........
although the dinky winkaz are still available!
u2u me
Holy thread resurrection batman!
Wiper mechanism - sold
Dinky winkaz - sold
Fuel pump - sold
Brake lines - sold
Thanks to all - there are actually still lots of bits left if anyone else wants to turn back the hands of time?
Are the brake hoses still available?
Chris
Hi Chris,
As per previous post sold Im afraid - cheers for your interest though
Still looking for pics of the be dion
