Ford 1.8/2.0/2.3 DURATEC Engine Mounts engine into the Haynes Roadster (7-Type) Chassis. Manufactured from 6mm Laser Cut Mild Steel Plates and 40mm
box section these are heavy duty brackets specifically designed for the Lotus Seven type chassis. These mounts allow the tallest 2.3 block to be
installed under a standard MK bonnet with the standard rocker cover (sump will require modification for ground clearance). The shorter 2.0 can
therefore be shimmed up to increase ground clearance.
Also included are the popular heavy duty Landrover V8 rubbers (M10 Male Studs). Price including carriage £80.
The individual plates that make up these mounts are also available (see my other posts) if you have a non-standard requirement.
[Edited on 12/5/11 by FASTdan]
